Question about Philips 46PP9302 46" Rear Projection Television
Can't seem to get the multi-points
I can't seem to get the multi-points, I can't get the points to move or anything.
You have to hit exit on you remote to move the multi-point system. i suggest using the volume and channel buttons on the tv to move the multi-points not the remote works better for me.
Posted on Feb 07, 2008
2005 ford focus zx4. No brake lights, turn signals or hazards. Fuse doesn't look like it's blown. HELP
Hi Sue:
I'd suggest using a voltmeter and start checking at the supply side of the fuse. AS these are all on the same circuit there's a failure at ome point so working "downstream" until you don't have power will ultimately locate the problem component.
Also, was anything done that might have caused the problem?
Re-phrased, At some point, they worked properly. What happened right before they stopped working?
It might lead you to the source of the problem.
Aug 03, 2015 | Ford Cars & Trucks
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Car won't start after switching baterries
re move alt. have it re tested i had a signaler problem. tested fine at idle under load alt surged blow batt. also volt regulator may be constantly draining battery voltage regulator is inside alternator
Nov 23, 2012 | Oldsmobile Cutlass Ciera Cars & Trucks
On my 1994 dodge stealth, My passenger window rolled down, now it wont roll back up, how do i fix it? The driver side still works.
please disassemble the door trim remove the power window switch,remove the connector,get a multi tester to check the switch,move down the switch point to the terminal 1 and 2,3,4.if ok,move upward point to terminal 1 and 2,3,4, if no reading replace the power window switch
Mar 17, 2011 | 1994 Dodge Stealth
Starboard needle keeps erratic behavior, engine does not lose rpm nothing seems abnormal, usual see this when gas has water but port engine runs fine from same tank and needle steady
My thought is this may be electrical in nature. I would test with an external guage. If your engines have points, make certain they are in good condition. I suggest considering upgrading ignition to electronic, but that has nothing to do with this event, necessarily. Points are just always out, slightly.
Another test, before anything, may be to reverse the inputs on the Floscan and see if the problem moves or stays. If the problem moves, the starboard ignition is suspect. If the problem does not move, the Floscan may need repair. Make sure that you have tight and clean connections and good grounds.
Dec 13, 2010 | Floscan Twinscan 0 8000 Tachometer
Weird lines moving on an 1st gen itouch
Hey,
follow this guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
in the end theres the warranty info checker, you may need to send this one to repair, check your warranty with the tool ones your done. Its the last thing on the guide.
Thanks,
Ekse
Feb 15, 2009 | Apple iPod touch
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Focus points
you cannot see all 51 AF points in the viewfinder. The purpose for this is not to block your view of the actual view. But the AF points are there. Just press the multi selector button to move the AF points around
Jun 20, 2008 | Nikon D300 Body Only Digital Camera
Multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Dec 01, 2007 | Philips 43P8341 43" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
