Back to:
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Sparking fire inside the microwave - Knemore Model...
posted by musa47 on Dec 07, 2007
I wrapped a potato in an alminum foil inside micorawave, a sparking fire burned the left rear plastic hock which holds the metal shelf. I cleaned inside the microwave but the sparking continue. After we removed the burned hock the sparking stopped. What should I do ????
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 07, 2007
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2982 votes
If the sparking has stopped, that should be fine.
If you have a burned spot you may need to sand it and repaint it with appliance paint from Wal-Mart, etc.
You can probably replace the shelf bracket / hook if it's still available.
If you'll post your brand and model, we'll see if we can steer you toward a source for a new shelf bracket.
If it's a Kenmore, you can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sparking fire inside the microwave - Knemore Model No. 721.80522500:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
removing an ols microwave model jvm48 -need help in...
Magic Chef MCD1311ST 1100 Watts Microwave...
How do I change the light bulb in my Magic Chef...
Microwave Ovens
Hi there, my microwave wont stop beeping in all kinds of...
Microwave Ovens
1996 GE Turntable Microwave.  Works perfectly except...
Microwave Ovens
need electrical schematic for sharp model#r-820bc...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
