Question about The Watches
Can u help me get in to do a first time user for the online induction for the Crown
Does Invicta 6981 have a screw down crown?
The Invicta 6981 does have a screw down crown to unscrew the crown turn counter clockwise and pull/push into position to set time, date and other functions . To close crown PRESS it against the case and turn clock wise .You should be able to get a users guide if you enter into your browser "users guide for INVICTA 6981" , it might be a PDF format that you can use for further use . HOPE THIS HELPS YOU OUT .
Dec 25, 2015 | Invicta Watches
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How do I set my watch
It all depends on the type of watch you have.
Manually, the time (and date) are set by releasing the crown wheel and turning it so that the hands move clockwise to the correct time. If you have a date function, you may have to cycle the crown wheel quite a few times to reach the correct day and date.
On digital watches, the user guide will indicate which buttons should be pressed to set the time and date. Refer to the user guide that came with your watch, go onto the manufacturer's website or go back to the store where you bought the watch and ask them to show you how to do it.
On smart watches, the time should be set automatically when the watch synchronises with your smartphone or wifi signal.
May 24, 2015 | Watches
How to set my movements on my watch
Unscrew, then pull crown out 2 clicks. Spin crown, advancing hands clockwise. Keep turning until you notice the date changing at the 12 oclock mark. This is midnight. Then set time as needed.
Push crown in all the way. Then pull out one click. Turning crown sets day of week and day of month, turning opposite way.
Push crown all the way in and slightly depress as you screw it down until it stops.
Oct 19, 2014 | Renato Mens T-Rex Swiss Quartz Stainless...
Is there an online instruction manual for Kenneth Cole Model KS3025?
i don't know about on line instruction.
but i could help you ....
there is two position for crown 1 and 2.
bring crown on position 2 and turn crown clockwise to change TIME, DAY & DATE.
bring crown position 1, and turn crown counterclockwise to change DATE.
your watch has Chronograph / Stop watch.
use that please press right TOP button chronograph will START, press again Chronograph will STOP.
Press bottom button to RESET Chronograph.
hope it will help 9k=
Jun 06, 2014 | Kenneth Cole Watches
I have a Timex automatic with day and date. How do I set the day and date?
I often sell vintage Timex watches which have a day and date feature. Setting the day and date feature can be a little tricky - if not frusterating if you aren't familiar with how to do it since most of the original manuals that came with these are long gone!
I'll try to explain the process - please feel free to contact me if this doesn't make sense.
1. Pull out the crown on the right hand side of the watch.
2. Advance the crown so the time advances clockwise until the day is correct.
3. Rotate the crown so the time is going counter-clockwise (the opposite direction) until the date "clicks". (the day will click first, then the date).
4. Rotate the crown so the time is going clockwise again and the date will advance.
5. Continue this back and forth action of rotation until the date is correct.
6. Push in the crown and you're done!
I'm considering making a video of this process. Please let me know if this is something you would be interested in.
Oct 30, 2010 | Timex Automatic Watch
Wenger Swiss Military Watch: small set-time handle fell off.
That small gizmo is called CROWN or WINDING CROWN. It is not possible to obtain it online, so, you have to shop around for it. Find your nearest watchmakers shop and ask for replacement. You may need stem as well.
Rate, please.
Jul 09, 2009 | Watches
User Manual
Your Omega Speedmaster has a three setting button,the two is for push button, and the center button is to wind button crown, To set the time you unthread the crown. When it is unthreaded the crown pull it, has a two pull the half pull and full pull , the half pull is for the date setting and the full pull is for the hour and minutes.When finished setting the time press it and screwing it to lock, so water cannot get inside. The two push button is for the stop watch,the above button for stop and go,, the lower button is to reset button .Just try to function the push button and observed what happen. feel free for further assistance in keep sending more question in comments or doubts that arise your mind regarding this to me,,rate the as fixya if it helps you understand in solve your problem....
Jul 25, 2008 | Watches
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Watches Logo
77 people viewed this question
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
