Question about OKI 9800hdn Laser Printer
Oki 9800 fatal error 230
Any idea how to clear or reset this code?
  • copiers Dec 21, 2007
    thanks for the input.problem was rfid board and stuck sensor under turn unit for jams. thanks
  • Anonymous Oct 14, 2008
    When i switch my OKI C9800 the dysplay shows a "POWER OFF/ON fatal error 917" what can i do to solve it
  • OKI Master
  • 1,113 Answers
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
  • Soulvisitor
    Soulvisitor Dec 21, 2007
    he toner cartridge
    natity in a toner
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Code p1495
The code will have to be reset at a garage. They have a small computer that plugs in near you fuse box, finds the code and resets it(turns it off). Hope this helps you
May 16, 2014 | Chrysler Concorde Cars & Trucks
2004 porsche cayenne i reset computer and now it will not start
Clearing Codes, clears all data, then all the emission
monitors have to run again, or you won't be excepted
to inspection
Clearing codes & data,has nothing to do with diagnosing
why you got the fault codes & fixing the problems
How would clearing a dash light help pass inspection?
Before you got down the street two houses, the light would
be back,the car has a failed system ,thus the light on the
dash after the motor is started.
You cleared all data,now a shop can't even work on it
You removed all vehicle history & codes
Flat bed it to a shop & they will make the repairs you neglected
to do, while trying to get hundred miles before the parameters
on a failed system went out of range & the dash light came back
Need to study OBD 2 Systems on the internet & leave the vehicle
work to the pros
Apr 10, 2014 | 2004 Porsche Cayenne
Reset check engine light
will have to purchase a obd II code reader to clear the code and reset ecm
Sep 16, 2013 | Toyota ECHO Cars & Trucks
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
System error E000
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
Feb 22, 2010 | Canon ImageRUNNER 1670F Copier
Ive forgoten me security code for my nokia 6300 any ideas?? my ime number is 358649017682685
hi im rain i will be helping you unlock your phone.
ok try this reset code.
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
-------------------------------IF the above code does not resolve issue then you will need to save all your pictures ect,.. and do hard reset.
Hard reset
Enter the code: *#7370# and press Yes to confirm initialization
phone will reboot
Nov 14, 2009 | Nokia Cell Phones
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
OKI 9800hdn Laser Printer Logo
1,330 people viewed this question
Top OKI Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Dominion Computer...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
