Question about AEG 24 in. Favorit 50730W Free-standing Dishwasher
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
    Problem Solver:
  • 14 Answers
We had the same problem with our dishwasher. It was filling up with cold water from the hot water line. Our plumber told us about Redytemp that would pump out the cold water in the hot water line just by pushing a button. We got one and installed it under the kitchen sink. We set the temperature on the Redytemp to about 115 F. Now all we do is push a button that looks like a doorbell and in 20 seconds all the cold water is out of the hot water line and we start our dishwasher. The dishes have never been cleaner.
Posted on Sep 05, 2009
  • 534 Answers
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Posted on Sep 02, 2009
SOURCE:
No hot water
If there is no hot water it could be (a) the heating element has gone or (b) the switching system has failrd somewhere - probably a relay or (c) the circuit card has gone (expensive)
Mar 23, 2014 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
Dishwasher
This "Inductive heating element"is in line with the pipe feeding the top spray arm. it is about 15cm long and has a clamp at each end with one electrical push on connecter. It can be reached by taking off the back bottom plate and just follow the spayarm down to this device.
Jun 05, 2008 | AEG 24 in. Favorit 40660i Built-in...
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Oct 26, 2007 | AEG 24 in. Favorit 50730W Free-standing...
AEG 24 in. Favorit 50730W Free-standing Dishwasher Logo
549 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
