Nintendo GameCube Console
Problem for Nintendo GameCube Console
Gamecube - blank screen, disc wont spin, power light and fan work.
By Firebomber40 on Dec 07, 2007
My Gamecube was working fine one day and then the next day i turned it on and all i got was a blank screen. The power light and the fan are working but the disc isnt spinning. It wont boot at all. I tried several different hookups and televisions but it was the same every time.
Clarification Request
Posted by tyownsuall66 on Jan 02, 2009
of course!! i think i have teh solution...make sure teher isnt alot of dust buildup in the gamecube because that will always cause a system malfunction
Same Problem
Jan 02, 2009
-   me to it was working andlater that night it wouldnt boot just the fan runs -   tyownsuall66
Dec 30, 2008
-   the solution is not working everthing is fine except for the screen and disc thingy
-   scottpeno
Dec 29, 2008
-   i borrowed my aunts gamecube and when i got it to my house it didn't work so i called her and she said it was left open for a month or two in her basement and i don't wan't to throw it out or buy a new one what do i do!!!
-   scottpeno
Dec 23, 2007
-   I have the same problem with a game cube..I had my first game cube for over 2 years and then it quit so I bought a refurbished one since i cant find a new one anywhere and I missed playing my games..so I got it and it didnt work says no signal and refer to manuel..I dont have a manuel and so I take it back and they give me another one this is my 2nd cube and it does the same thing as the first one I hooked it up to 2 tvs and got nothing! so i take it back and got another one this is my 3rd one, by this time i just wanted my money back but they insisted..so I plug this cube up and it works for 10 secs and then say refer to manuel! wtf! whats wrong with it the disc doesnt spin on the 3rd one and Im fed up I think Ill just get a WII!-   jlynne26
Dec 11, 2007
-   I can"t get my Gcube to workl it turns on for few but then shut off and the only thing running is the fan-   PaIgiE
Solution #1
posted on Dec 13, 2007
Somewhat Helpful)
CordellNJ
Rank: Master
Rating: 83%, 41 votes
Troubleshooting - Power
No Power
Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
If this fails, try resetting the AC adapter.
Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
Power Light Flashes
If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 23, 2009
Not Rated)
octoberrose9
Rank: Apprentice
Rating: 0%, 0 votes
Just get a new gamecube, apperently it's broken. the same thing happened to mine, and the store couldn't even fix it. I hope this helped:)
Was this helpful?
Yes
No
Popular Solutions for Nintendo GameCube Console
Questions and Unsolved Problems for Nintendo GameCube Console
Do you recommend Nintendo GameCube Console?
Answer
Answer
i type in my pin and it says wait because i've got wire less internet and it says communication... (More)
Answer
I get a screen, but it won't start the program.
Answer
my gamecube won't start up. what should I do. I am one of those people that opens up their systems... (More)
Answer
game cube says error when turned on any ideas how to fix
Answer
when I turn my gamecube on and I have the game in it. it say's to turn off and read the instrution... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
