Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washing machine
It is leaking water from the bottom onto the floor.
Cant figure out why.
  • 3 more comments
  • kevinskywest Dec 11, 2007
    leaking around the motor underneath, washed a large load of rugs, now it leaks a little on the floor
  • Anonymous Dec 14, 2007
  • Anonymous Dec 22, 2007
    all water leaks out onto floor
  • Anonymous Jan 14, 2008
    Water leaks on floor after a wash. Model # MAV6200AWW Contacted Maytag and got absolutely no help. They did tell me the machine was made feb 2001, so it is only seven years
  • jimmyjam_p Oct 01, 2008
    water leaks from underneat the washer when it is draining
It will not spin out all of the water out of clothes, spins VERY slow
Posted on Dec 10, 2007
Water draining from bottom of washer when I went to fill up. Completely drained all over floor within minutes. What the heck is going on?
Have you checked your hoses in the back? The water may be going to the floor instead of the washer. Check around the water pump as well.
Mar 05, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Washer is over filling.
Hi, Does water enter the machine when there timer is off or even if the machine is unplugged? If this is the case, the inlet valve needs replaced. If the water stops when the timer is turned off, there is a problem with the water level switch. Please let me know so that I can assist you further. Thanks
May 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis water valve started leaking when not running
I figured out how to get the encasement (plastic covering) off and get to the water
valve. Successfully changed it, then when I went to turn the waters back on, the hot faucet
began leaking from the know!!! Go figure, I get one problem fixed and now I must deal
with another.
Thank you.
Apr 05, 2009 | Maytag Washing Machines
Leaking water
If it was moved with a dolley the dolley may have broken the water pump under the washer.
Mar 14, 2009 | Maytag Atlantis MAV8000
Tub leaks water during cycle out bottom onto floor
We had the same problem. There was a pinhole leak in the hose that connects the tub to the pump. Bought a new hose for under $10 and fixed the problem ourselves.
Feb 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer machine leak
hi thanks for your question sometimes the little hose that goes to the water level switch gets clogged up with lint telling the timer it does not have enough water a plastic hose goes there find it and blow through it but look at it take it off to make sure its clean it happened me to dat thanks for the question THE APPLIANCE DOC
Sep 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
461 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
