Question about Panasonic FP-7735 Black and White Copier
How do I get the drum out to replace it
How do you get the drum out of the panasonic fp-7735. I know I can not expose it to light and intend to put it right into a dark paper bag. I just can not figure out how to get it out. Is there a lever? If so were is it. Help me find it.... I see nothing in the manual it came with
  • Robin Wilson Dec 11, 2007
    You are a life saver! I got it out, cleaned it and am now running copies. Yea it's old! No one will service it so they are stuck with me.
    thanks a million
  • 25 Answers
It's bad to leave those older drums out in light, say over the weekend. But a couple hours will be fine.
Posted on Jan 24, 2008
    Problem Solver:
  • 18 Answers
First i must say i,m not an apprentice, i,m 25years knowledge. Thats an oldy. dated 1995-1997. open the front door, to the right under or by developer unit theres a lever, flip it right or left,(cant remeber) this moves the developer unit to the right away from the drum. then between the drum and cleaner unit is a small black cover, remove it, ( about 2in. square) under that is i believe 1 or 2 screws that hold cleaner assy and drum in. Carefully slide them out but first disconnect discharge lamp connectors, maybe remove th #1 charger to prevent drum damage and drop #2 charge assy down out of the way so you dont slide the drum accross it as it comes out. just go slow, maybe the cleaner unit on the left side of the drum unit willstay in the copier. its been awhile since I did one. Dont worry about the bag, thats an old wise tail. I,ve never covered a drum except to keep my sweat from dripping on it in a 102 degree office. , beside they rejuvinate within the first 10 copiers after going back in. good luck, i,ll be here.
Posted on Dec 08, 2007
Panasonic fp-7735 is working good but if i make a copy the paper copy result is complete black
Check and see if the light under the glass is lighting up. If not, that is your problem.
May 15, 2011 | Panasonic FP-7735 Black and White Copier
My Panasonic FP-7160copier is showing code: c0210. What does it mean?
C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
Copies are light
try shaking the toner bottle up, then putting it back in.
Apr 19, 2010 | Panasonic FP-7735 Black and White Copier
I like to sell it itr wors good Panasonic FP-7735
please consult your local newspaper to advertise. this is an old copier with old technology .
Apr 18, 2010 | Panasonic FP-7735 Black and White Copier
ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
May 05, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Apr 09, 2009 | Panasonic FP-7735 Black and White Copier
Drum for FP-7735 HELP?!
Would reccomend that you get a technician to do this as he will need to reset settings in the copier.
Dec 13, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP 7742 Copier
check drum and drum sensor. if the Drum cleaning blade (DCB) has failed and is smearing toner around the drum then the drum sensor can't see the drum. clean it with a brush. the sensor sits in the drum/ cleaning station.
Oct 14, 2008 | Panasonic FP-7735 Black and White Copier
Need to replace the drum cleaning brush how do I get it out????
The drum cleaning blade removal is pretty straight forward.
1. Remove the charge unit above the drum.
2. Remove the cover that sits above the cleaning blade.
3. Release the pressure spring at front of drum unit.
4. Remove 1 screw (front side of blade at top) holding blade in place.
I noticed that you had also had a E3-40 code previously. If toner is dropping on to your copies, the toner support blade will also have to be replaced.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
120 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
