Question about Jensen VM9510 Car DVD Player
I need toby past e brake - Jensen VM9510 Car DVD Player
All I did on my Jensen VM8022 was ground the parking wire on the chassis of the radio. No "secret menus" no hassle. I put a flat u connector on the end of the wire and loosened one of the screws on the back attached the wire then tightened the screw back down. To make sure this will work with your radio just touch the wire to the metal radio body.
Posted on Dec 23, 2007
I want to know if there is a brake bypass for the jensen vm9512
Posted on Dec 14, 2007
On your remote control press 1 2 3 4 and then press and hold the number five until the hidden menu appears
there is an option to by pass the brake
David
Toby Y7573P baby monitor,1yr old,will not take charge or turn on
Yes, but it could be many other things too.
Oct 14, 2014 | Baby Gear
Where can I buy tobi steamer parts
Have you tried Tobi? The manufacturers usually can supply parts.
Sep 03, 2014 | Cars & Trucks
Samsung tobi restricted to network lock. Just release it
Hi. To which specific network has your Samsung Tobi (S3030) has been restricted to? You can unlock your Samsung S3030 Tobi safer and easier using unlock code. You can get the unlock code for a Samsung S3030 Tobi from Unlock-Zone.com at affordable cost with easy unlocking guide. Good luck.
Jun 27, 2014 | Cell Phones
Printronix p5210 firmware
Hello Fadel,
I emailed 2 different Emulation files...
Let me know if you receive an error. If you get Flushing Ques after you started the download, then you don't have enough Dram memory, Flash memory or Security Pal chip needs a specific Emulation file.
Jul 09, 2012 | Printronix Line Matrix P5210 Printer
I need to clean a child's sickness from the base of my Toby. How do I seperate it?
Hi
It isn't recommended that you take apart the plastic shell of the carseat. You can remove the fabric from the carseat to wash it and then clean the shell with warm soapy water but it is not advisable to remove the harness or to take apart the factory seal of the shell.
Have a look at www.maxi-cosi.com and select the country you're in, then choose the Tobi carseat and select the instructions to view directions on how to remove the fabric.
Sep 24, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Jensen VM9510 Car DVD Player Logo
267 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
