Question about Cuisinart DGB-600 Coffee Maker
The bottom warmer no longer heats up
The warmer not longer heats up to keep the coffee warm. Has anyone made this repair?
  • chloepatches Jul 14, 2008
    Same thing how do we get this maker fixed? Looking for customer service # to fix this problem! Does anyone have it???? Any help will be appreciated. Thank You,
  • 833 Answers
Generally, the cost of parts makes this prohibitive.
Posted on Jun 02, 2008
Saw a coffee warmer at WALLMART in Montr?al Canada, look it up where you live.
Oct 29, 2014 | Coffee Makers & Espresso Machines
The freon is fully charged but the air keeps getting warmer until there is no longer any cold air. It still blows air but it's warm. Does this sound like the compressor is bad??
do you have to recharge it after it starts blown warm if so its just got a leak and leaking all your freon out if its holding all freon then compressor must be bad
Sep 14, 2012 | Air Conditioning and Heat for Isuzu Axiom
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Lukewarm water...tank do I fill it if it is supposed to fill automatically from an outside line?
It looks like this brewer has a fill lid on top. If you remove the screw on the lid you can remove it and pour cold water through (1/2 gallon per pot). If the brewer was energized and NOT filled with water before hand there is a good chance that the heating element burned up. The reason you would still get "lukewarm" water is due to the keep warm heater around the tank. It is a low voltage warmer that keeps the reservoir warm without the main heating element kicking in.
Aug 25, 2010 | Bunn CRTF5 Coffee Maker
Water wont heat. Warmer has no heat but light is on
Hello, One of the wires soldered to the underside of the warming plate had fell off due to poor soldering.The warming plate and the warning light are connected together with piggy back connectors so that is why the light is on even when the warmer is cold. Bye
Jul 03, 2010 | GE 106591 Coffee Maker
I just get bunn VPS it is and work very good
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
May 16, 2010 | Bunn VPS Coffee Maker
Using a thermal pot
I also bought the thermal carafe; before I could hack the warming plate, my wife set the "Auto Off" feature to 1 minute, which shuts off the carafe heater. The settings are preserved unless you lose power for an extended period.
The warmer does still warm through the brewing cycle but it doesn't overheat the carafe (IMO.) Hope this helps.
May 29, 2008 | Cuisinart DCC-1200 Coffee Maker
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
71 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
