Question about Toshiba Satellite A135-S2276 Notebook
Forgot password I forgot the password. How can I login? Is there something I can do? forgot password
  • Anonymous Dec 12, 2007
    WHEN I TURN THE COMPUTER I SEE BLUE SCREE ASKING FOR PASSWORD
    Problem Solver:
  • 11 Answers
The questions are list below:
1. Do you want to login your PC directly without a admin account and password? (You know your admin account name and password together)
For this question, you can follow this detailed guideline:
When you start Windows 7, you are asked to enter your password to be able to log in. This is to protect your PC from unauthorized access. But if you are the only person to use the PC and if you do not wish to be asked for the password every time, you may get rude of this process.
To be able to log in to Windows 7 without entering any user name or password, type control userpasswords2 in start search and hit Enter to bring up the User Accounts window. Alternatively, press Win+R to bring up the Run box, type control user passwords2 and click OK.
Uncheck Users must enter a user name and password to use this computer and click Apply > OK.
On restart, you will henceforth not be asked or prompted to enter your username and password.
2. Do you lost your windows password?
You can recover your Windows domain password and local password in a few minute!
A blank or bootable CD/DVD or USB flash drive is required to reset Windows password
Step 1: Download the Windows Password Recovery Tool 3.0 and install in any available computer ( http://www.www.windowspasswordsrecovery.com )
Step 2: Burn a bootable CD/DVD or USB to reset Windows password
Step 3: Set BIOS to boot from CD/VD or USB
Step 4: Reset lost Windows password with the burned CD/DVD or USB
Posted on Dec 06, 2011
  • 40 Answers
Restart your system then press F8 upon booting then select "Safe Mode". then log in as an ADMINISTRATOR. when you are on the windows with Safe Mode, go to Control Panel, then select User Account, Then select your account which you forgot your password, then delete the password. then restart your system in normal mode. you can now create new password for your account. guud luck!!
Posted on Dec 07, 2007
    Producer:
    Uploaded 30 video answers.
    Novelist:
  • 62 Answers
If you forgot the Windows login password and want to recover or reset Windows password, there is two methods to help you reset the Windows login password:
Method 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows password.
Method 2: Using Anmosoft Windows Password Reset to recover or reset Windows password, it support Windows all Windows versions like Windows 7, Vista, XP, 2000 and Windows Server 2008(R2), 2003(R2), 2000, etc
Anmosoft Windows Password Reset software recover or reset Windows password by four steps:
Step1: Download Anmosoft Windows Password Reset V8.0 and install it.(Download from here: http://www.resetwindowspassword.com).
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Posted on May 07, 2012
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
Anmosoft Windows Password Reset is a powerful and professional program that enables you to create a password reset CD/DVD. When you need windows 7 password recovery, you can use the created CD/DVD to reset the forgotten password in just 3 simple steps:Step 1: Download and install the software on an accessible computer.Step 2: Put a blank CD/DVD or USB drive into the computer to create a password reset disk.Step 3: Insert the password reset disk into the locked computer and follow the password reset wizard to reset windows 7 password.
Posted on May 02, 2012
  • 89 Answers
Simply you can use administrator account to login into your computer system. when blue login screen appear then press Ctrl+Alt+Delete. administrator login windows will be open. write "administrator" in username textbox and leave password black, now hit Enter you will be able to login. If you lost both administrator and user password then use windows password recovery software
Posted on Apr 02, 2012
    Problem Solver:
  • 10 Answers
The most simple way is to just to buy a tool like Windows Password Reset 9.0 It will save your plenty of time and it is very effectively. http://www.reset-windows-password.com/reset-windows-7-password.html
Posted on Mar 03, 2012
    Problem Solver:
  • 7 Answers
Solution 1: Reset windows password with password reset disk.
1. If you enter the wrong password when you attempt to log on, Windows displays a message that the password is incorrect. Click OK to close the message.
2. Click Reset password, and then insert your windows password reset disk (or other removable media).
3. Follow the steps in the Password Reset Wizard to create a new password.
4. Log on with the new password. If you forget your password again, you can use the same password reset disk. You don't need to make a new one.
Solution 2: Reset (recover) windows password with password software.Steps as below:
Step 1: Download and install Spower Windows Password Reset.
Step 2: Create a CD/DVD or USB password reset boot disk with SWPR.
Step 3: Boot your computer from password reset boot disk.
Step 4: Recover the forgotten password for administrator account.
For more information, please visit our site:http://www.windowspasswordsreset.com/
Posted on Jan 30, 2012
    Problem Solver:
  • 10 Answers
I suggest you try hard to remember your password! If you really can not reset your windows administrator password, I recommend Windows Password Seeker, passwordseeker.com
I had removed Windows password with the tool successfully on my computer. Hope it helps! You simply do as follows:
Step1, download Windows Password Seeker.
Step2. Remove your Windows Password with the tool.
If having some questions, you can read carefully at: http://www.passwordseeker.com/howtouse.html
Posted on Dec 07, 2011
    Problem Solver:
  • 9 Answers
Reset it with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com/how-to-reset-windows-password.html last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Posted on Nov 30, 2011
    Novelist:
    Scholar:
  • 175 Answers
Once forgetting windows password, you can bypass windows password with third-party password reset tools, take Windows Login recovery for Example, it is professional software woking for windows password reset. You can download it and follow its guide to burn a password reset CD/DVD or USB falsh drive to get your password reset or bypassed.
Posted on Nov 10, 2011
  • 383 Answers
You can crack password:
Follow these steps :
1) Restart your pc and press F8.
2) Open your pc in safe mode with command prompt.
3) Then go to C:/windows/system32/>
4) type in it this one:
C:/windows/system32/> net user (username) (newpassword)
->in username use the name administrator or username for which u want password
-> dont worry about old password type your new password.
->Login with your new password. Good Luck .....Dont for get to Vote. Merry Christmas
  • bessadluse Nov 05, 2011
    You can remove or reset it. I highly recommend windows password reset tools. Last week, and then I downloaded one and used it to remove the lost password successfully.http://www.reset-windows-password.com/
5 Suggested Answers
  • 79 Answers
SOURCE: I forgot my Password to the Login of my Laptop
hi
press ctrl-alt-del thrice at the login screen and at the next login screen enter user name as "administrator" and leave the password blank.
hope this solves ur problem.
Posted on Jul 22, 2008
  • 157 Answers
SOURCE: forgot login password so my ibm laptop is completely locked what do i do?
Are you using XP, you can boot in Safe mode and log in as Administartor(usually it does not have any password), so login with Admin account and remove the password of your account. and then restart the system to Normal mode to get your system working.
But unfortunately in case if it is Vista, there is no other option other then formating the whole system.
Posted on May 07, 2009
ticthak
  • 43 Answers
SOURCE: I can't login because I forgot my password
OPHcrack is a password cracking program (legal and open-source) included in many (if not most) linux-based boot disks like UltimateBootCD, Knoppix, RescueCD, and many others and on its own (as OPHcrack)- a no-brainer to run, you just cold-boot with the CD or other removable media drive set as 1st boot device in BIOS or select from the boot device selection menu before the OS loads. These boot disks will ask you for some input to run (read the prompt), OPHcrack will run directly, other disks will require a few other steps to run the program.
Posted on Aug 13, 2009
mahhek
  • 662 Answers
SOURCE: forgot my toshiba laptop login password ? can u
It is not a big deal. You can try the safe boot option
restart the Laptop in safe mode by pressing the F8 key while rebooting
Select safe mode on Advance boot option
Log in as administrator
Go to control panel and Delete the previous User and create another user with same name
Restart the computer in normal mode
If this Works please say thanks and If this does not work let me know, I'll give you other options
Posted on Oct 05, 2009
I have forgot my facebook password and my e-mail password....how do I recover my fb account?
To see if you have these options:
  • Go to the Facebook login page and click Forgot your account? ...
  • Fill out the form to identify your account.
  • Select I forgot my account on the next page if prompted.
  • Look at the list of email addresses listed on your account.
I can't reset my password because I can't access the email ... - Facebook
https://www.facebook.com/help/132243923516844?helpref=faq_content
  1. Cached
To see if you have these options: Go to the Facebook login page and click Forgot your account? Fill out the form to identify your account. Select I forgot my account on the next page if prompted. Look at the list of email addresses listed on your account.
iv forgotten my password for fb and my password for my email what do ...
https://www.facebook.com/help/community/question/?id=446918838749743
  1. Cached
  2. Similar
iv forgotten my password for fb and my password for my email what do i do? ... on my Facebook and on my email and forgotten them both....now i have a different ...
I forgot my old login details, email and password. How do I ... - Facebook
https://www.facebook.com/help/community/question/?id=10151487935427404
  1. Cached
  2. Similar
Hi everyone, If you can't reset your password because you can't access the email address connected to that account, you may be able to get access by ...
I forgot my Facebook password and email password. How can I log ...
https://www.quora.com/I-forgot-my-Facebook-password-and-email-password-How-can-... That is a rather unfortunate situation you're finding yourself in. In the case you still have access to the email address you signed up with, but you don't remember ...
how to login facebook if you forgot your username/email - YouTube
z? 10:16 https://www.youtube.com/watch?v=lk4OJotB6xw
  1. Similar
Apr 22, 2013 - Uploaded by sheelu mishraa for more videos email sheeluthemishra@gmail.com. ... If you got problem ask here ... i lost my email, my ...
How do I recover my Facebook login password? - Ask Leo!
https://askleo.com/how_do_i_recover_my_facebook_log_in_password/
  1. Cached
  2. Similar
Aug 4, 2010 - I stupidly forgot my Facebook login password and can't get on. Now what ... Unfortunately, Facebook won't email you your password. But that's ...
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Similar
  1. Cached
  2. Similar
Aug 4, 2010 - I stupidly forgot my Facebook login password and can't get on. Now what ... Unfortunately, Facebook won't email you your password. But that's ... have forgot my facebook password and my mail password Google Search
Jun 15, 2017 | Facebook Computers & Internet
Recovering my fb password
  1. Go to the Facebook login page and click Forgot your account? or Can't login? in the top right.
  2. Fill out the form to identify your account.
  3. Select I forgot my account on the next page if prompted.
  4. Look at the list of email addresses listed on your account.
More items...
https://www.quora.com/I-forgot-my-Facebook-password-and-email-password-How-can-.. Recovering my fb password Google Search
Nov 28, 2016 | Computers & Internet
Can't access forgot password
In this case, check if there is "Forgot password?" or similar option available on the login page. Click on this option and follow on-screen instructions to reset your password.
GuruAid.com
Feb 19, 2016 | Computers & Internet
Forgot My Login Password on my PC on the outlook
which password you forgot computer user name password
Aug 03, 2013 | Computers & Internet
I forgot my phone's password,what would i do?
just try to login over and over it would say authorize account With Gmail Or Idk But Theres Something Elese
Dec 25, 2012 | Acer beTouch E110 Android 3MP Unlocked...
I forgot my password on ourworld.com
Go to the website and click on the member login button in the right hand corner. When the login comes up, click on "forgot your password" link and enter your info so they can reset youru password.
Nov 23, 2012 | Computers & Internet
I Forgot my old facebook password and i can't login i Need A New Password Help Please
On the Facebook login page click on Forgot Password? and follow the instructions to reset your password.
Dec 18, 2010 | Facebook Social Network
Login name and password
You forgot your login name and password for what?? and if you contact the company and tell them what email address you used they can send you a security question or something that you set when signing up and then they will set it..
Nov 06, 2008 | Video Game Consoles & Games
Toshiba Satellite A135-S2276 Notebook Logo
690 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
