Question about Konica Minolta DiMAGE X1 Digital Camera
Blank white screen
When I turn on the camera the screen is just bright white but you can take pictures which I have viewed once downloaded to my computer. The screen remains white , I have charged and removed the battery numerous times.
HELP!!!
  • 1 more comment
  • acclg Feb 19, 2008
    once it happened to, but some air conditioned was the solution, I thought that it get wet, but know it happened again, and donĀ“t know why? How do I fix it?
  • badengdengda Mar 31, 2008
    Yes same problem - white screen and can't see/ monitor anything on the LCD. Help!
  • Paul Hertel
    Paul Hertel Nov 24, 2008
    remove 4 hex screws .059 dia, and one micro phillips from tripod mount hole. carefully pry halves apart and re-seat both ends of the ribbon cable push in end tabs with a small needle. turn camera on to verify lcd is working. carefully reverse disassembly procedure.
    Wrked for me on my DiMage x1.
The problem is that the heat by the chassis of the screen LCD melts the insulating material of some electric cords located behind this one ( when the cords are in contact with the chassis).
To fix the problem it is necessary to disassemble the apparatus by the four back screws, to check the cords (red and black and on the upper part on the right on mine) and to do again insulation
Posted on Aug 11, 2008
Hey, try this FIRST. I just did it accidentally and it fixed for me. I got this camer as a parts camera on Ebay for $20 bucks. You know how there is a line in between the front and the back of the camera. Just hold the camera inbetween your fingers and shift it. Could be that you dropped your camera and the front and back shifted.
I fixed mine!
Posted on Apr 17, 2008
Https://www.precisioncamera.com/onecart.php
$111.00 to replace the LCD.
Posted on Dec 17, 2007
Fuji finepix 5600 white stripes
When you say 'played back', do you mean viewed on the camera screen, or after downloading to your computer ? If the latter, it could be to do with the software you are using - try FastStone.
Apr 18, 2017 | Fuji FinePix S5200 / S5600 Digital Camera
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
Blank LCD on Canon A95
Believe that you accidentally pressed the DISP button on the bottom back row of your camera. This manually turns the display on and off as desired to save batteries. Press the button once more to turn it back on.
Feb 21, 2009 | Canon PowerShot A95 Digital Camera
White preview screen after pic taken
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Nov 20, 2008 | Fuji FinePix S7000 Digital Camera
Bright white light
I have had the same problem with my F-700
After calling Fujifilm Custom support here in Spain, I've noticed that camera series had a common failure at CCD SENSOR, NOT THE SCREEN.
IF THE PROBLEM IS CCD (IMAGE SENSOR) FUJIFILM WILL REPAIR IT FOR FREE!!!!
I AM NOT KIDDING. I'RECEIVED A MAIL FROM FUJI SPAIN ABOUT THAT
ALSO CHECKED THAT AT FUJIFILM USA THEY REPAIR IT FOR FREE
I guess the problem is CCD (at least in mine) because:
1- Started with
intermitent colour distorsions (dissapearing from time to time)
2- The problem became more frequent as time passed by
3- THE IMAGE IS PERFECT WHEN I PLAY PICTURES FROM THE MEMORY CARD
GOOD LUCK !
Fernando
Nov 05, 2008 | Fuji FinePix F700 Digital Camera
Blank camera screen
I hope you sent it back to Fuji before your guarantee ran out.
Sep 07, 2006 | Fuji FinePix E550 Digital Camera
Konica Minolta DiMAGE X1 Digital Camera Logo
379 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
