Magic Chef CDB6100 Built-in Dishwasher
Problem for Magic Chef CDB6100 Built-in Dishwasher
No water supplied
By mcmbigmac on Sep 02, 2009
no water supplied
Best Solution
posted on Sep 02, 2009
Very Helpful)
kenmorris26
Rank: Guide
Rating: 88%, 3 votes
float could be stuck . pull the float inside the dishwasher up and down then try it. could be a bad pump, or angle stop is closed or clogged. if float doesn`t work. turn the water supply line off located under the kitchen sink. make sure it`s off by turning the hot water knob on your kitchen faucet. unplug the unit also under the sink. take the bottom cover off and look for the supply line that goes into the water pump. unscrew the supply line. get a bucket and turn the water supply back on just alittle to see if tou get water coming out. if you do it`s not clogged. so it`s either the pump or it`s the timer switch 9 out of ten times it`s the timer switch. good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Magic Chef CDB6100 Built-in
Questions and Unsolved Problems for Magic Chef CDB6100 Built-in
Do you recommend Magic Chef CDB6100 Built-in Dishwasher?
Answer
Answer
my dishes are dirty and the glasess have ground up food all over the out side and the bottom that is... (More)
Answer
Did not finish the cycle last night but continued to make the sound as if the pump was still... (More)
Answer
Hello Mr Fixit, When I turn the dishwasher to the normal clean cycle, I can hear it very quietly... (More)
Answer
I had my kitchen drain snaked. When I tried to start the dishwasher, the water entered, but it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CDB6100 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
