As you might know this model (Panasonic KX-P1121) uses a parallel cable, and my PC has no port for that, soI have a USB to parallel converter and the printer is connected to my PC (Vista, meaning the printer driver is build in), the problem is when adding the printer, I don't know what port to choose, I've chosen a USB port and it printed a test page (correct info about the PC) and all was good, but afterwards any printing order is NOT being executed, not even that test page, what now?
I assume you installed the driver that came with the cable. The driver should create a new printer port like lpt1. That's the port you should use in the printer configuration.
Belkin makes a USB Parallel Printer Adapter cable Part # F5U002au
Comments:
Sep 02, 2009
- Another way is to use a print server on your network. The printer is connected to the print server that has a LPT printer connection. Any computers on your network can then print to this printer.
it says i have to download a high speed usb controller for my wireless usb adapter for it to be...
(More)
it says i have to download a high speed usb controller for my wireless usb adapter for it to be faster. i have a dell where do i get this download
On IMac OS 10.4 The printer gave me the choice of printing both sides.
On )S 10.6 that choice has...
(More)
On )S 10.6 that choice has disappeared.
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. WHAT I HAVE TRIED, FOLLOWING EARLIER FIXYA SUGGESTIONS since then. I have. 1. turned printer upside down 2. gently cleaned out paper dust on either side of the paper rollers 3. checked that paper roller is still rough 4. tried to change to feed from lower cassette. will not accept feed switch command 5. removed and reinstalled print head (which was replaced last month) PROBLEM REMAINS. turned machine off and on. after being turned on, a sheet of paper will pass through the machine but paper jam message continues. QUESTION: WHAT TO DO? Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL...
(More)
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL PROBLEM paper jam problem began when a dangling telephone wire got caught in paper intake. it was removed very gently. no error message. Tried to print, got error message at ejection slot turned machine off and on. after being turned on, a sheet of paper will
pass through the machine but paper jam message continues. QUESTION: Background: we have in past two months cleaned the WASTE TANK following the instructions here and reprogrammed it and, after the print head refused to print from the smaller of the black cartridges, replaced the print head. We get a flashing light when printer is turned on and a small grind, but then the light disappears.
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low...
(More)
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low memory
