Back to:
Tags:
Acer PD525 Multimedia Projector
Toshiba portege m600 cannot connect to projector... (by 3 users)
posted by ehartono on Dec 07, 2007
I have never success to display my presentation if I use toshiba portege M600 and connected to projector Acer PD525. The display is only "no signal". I had reduce the display resolution to lowest. Change with good cable. But its ok if I use another projector such as Infocus. And its oke too if I use another laptop. Please advice and help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 08, 2008
I can't get the signal out to any external display... I assume it's a software issue since some other friend has the same laptop but it works fine. I tried all options but nothing works.
Comment by Guest, posted on Feb 20, 2008
default screen stays on
Best Solution
posted on Jul 15, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
you can extend the display to the projector through desktop settings
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toshiba portege m600 cannot connect to projector ACER PD525:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
No power-dead. Tested with known good power cord, fuse...
We are using Windows XP SP2 and can not get the full...
hi marrie, i am a teacher in turkey, but i have a problem...
Using Acer "My Start-up Screen" program to set...
Everything works from my Fijitsu Siemens Laptop to the...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
