Question about Sony PlayStation Portable (PSP) Console
Psp my dad microwaved my psp and now my memory stick fried and the down directional button doesnt work what do i do?
  • Anonymous Dec 27, 2007
    i had the same problem with my first psp,10 minutes on full power[100%] and it was useless.Try low power [30%]for 6mins and although
    quite unedible can still be used as a entertaiment device.
    the psp does not like marinades! i expect your dad made this mistake the night before cooking,never cook a psp in a microwave always use a conventional oven [200c]
Was it from frozen or defrosted?
Posted on Dec 27, 2007
Buy a new psp
Posted on Dec 07, 2007
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
I have bought the Breath of fire 3 game for PSP and i have a formatted 4gb memory stick duo. It tells me over and over that there is insufficient memory. I verified i do not have a fake memory stick.
Does the memory stick work with other games. Did you remove the memory stick and format in windows?.Maybe you formatted using the NTFS file system if formatted in windows.Format the memory stick again in windows to FAT32 and it should work.
You can format any size Memory Stick Duo in the Sony PSP by doing this:
  1. Push the little HOME button on the bottom left of the face of the unit.
  2. Use the arrow keys to move to the SETTINGS area, then move the up and down keys until you get to System Settings.
  3. Once you are there, click on the "X" button and scroll up and down as needed to find Format Memory Stick. Click on "X" again to select that option.
  4. The Sony PSP will now confirm that you want to reformat the memory stick (which removes every file and game save thereon, of course): choose yes and it'll format in just a few seconds.
Now you have a pristine new Memory Stick to work with and should have no problems with music, photos or other material you might seek to copy onto your PSP.
Hope this works...
Jan 19, 2011 | Capcom Breath Of Fire III for PSP
My psp files gone
I assume you have a PSP with customize firmware.
1. Turn on your PSP and press the "SELECT" button and the VSH Menu will appear.
2. Scroll down to USB Device and change the setting into "Memory Stick".
(Use the up & down directional button to scroll and use the left & right directional button to change the setting.)
3. Scroll down to UMD ISO MODE and change the setting to "SONY NP9660".
4. After you change the setting EXIT to the main console and restart your PSP.
If this solution did not work come back and we will try other solutions.
Jan 21, 2010 | Sony PlayStation Portable (PSP) Console
My music doesnt work when i sync it to my psp..how do i put music on my psp?
You must have a memory stick in your PSP to add music or pictures to it.
When I connect my PSP to my computer with USB or pull the memory stick out and stick it in a card reader, I can copy music directly into the (drive letter):\MUSIC directory. Then when I disconnect the PSP or reinsert the memory card into it, the music is there to play.
Sep 18, 2009 | Sony PlayStation Portable (PSP) Console
Misfunctioning 4GB memory stick pro duo
Are you formatting it with your computer or PSP?
It that doesn't work - try formatting it with your computer.
Jul 09, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
PSP Update -- Memory Stick could not be read.
ok if the stick is to small it wont work but what are you really trying to do! mod it well here is how you do it!!!!!!!!!!!!!!!!!
http://forums.afterdawn.com/thread_view.cfm/688507 read about five comments down!!!!!
Jun 13, 2009 | Sony PlayStation Portable (PSP) Console
My psp cant read memory card
I suggest buying a new memory stick but i dont really suggest the 8gb because it crashes
or try removing the memory stick and putting it back again.
May 21, 2009 | Sony PlayStation Portable (PSP) Console
I just purchased a sony used psp for my grandson.
Follow the directive below to;
Step 1. Put on your PSP and use the arrow keys to go to "Saved Data Utility". Scroll down to "Memory Stick" and press the O button to get into the games stored in your memory stick.
This would enable you play your games on your memory stick, but if you are still not able to do that then get a UMD to play games or verify the version of your PSP.
You can only play the games in the memory stick after the PSP has been hacked.
Regards
Mar 16, 2009 | Sony PSP (Piano Black)
The music I put in my psp doesnt work
Make sure you have it in the "MUSIC"(all in caps) folder within the PSP folder of your Memory Stick.
Inside the Memory Stick's PSP's MUSIC folder, you should either have the song file itself(mp3 or wma) or no more than one folder.
I.E:
Memory Stick>PSP>MUSIC>Gwen Stefani>Don't Speak.mp3
or simply
Memory Stick>PSP>MUSIC>Don't Speak.mp3
Aug 08, 2008 | Sony PlayStation Portable (PSP) Console
Memory Stick Problems
Was memory stick formatted in psp,if not psp will not recognize standard memory sticks.Start psp,go to settings icon,push down button to system settings,push x then down to format memory stick.
May 10, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
