Kitchen Ranges Logo
Posted on Sep 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore gas stove not coming out of pre- heat model 66575842001
Working on a kenmore madel by whirlpool. 2000 unit model # 66575842001 the unit will start the pre heat cycle, run for one min and then then flame goes out and never try's to re-ignite. the display will stay on the pre-heat mode untile i turn it off. This unit has a spark ignition set up for bake not a glow bar. any ideas
Craig Butler
Level 3:
President:
  • Master 1,730 Answers
  • Posted on Sep 02, 2009
Craig Butler
Master
Level 3:
President:
Answers
1730
Questions
0
Helped
697662
Points
4778
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Whirlpool super capacity 465 gas stove. The oven will heat up but doesn't want too stay heated. What should I do to fix this problem?
Could be a weak ignitor. How old is the unit? What model do you have? Does the broiler work? Need more information. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
1helpful
2answers
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
Burners on the gas range spark but gas does not come out of any of the burners. The electrical gas shut off valve does not open.
Try this website! http://www.managemylife.com/mmh/owner_manuals/8534/KENMORE-Free-Standing-Gas-L0212001 (Hope this helps. If you have anymore questions, let me know.)
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
1helpful
My gas stove model # 790.77471792 does not heat up past 100 deg. The broiler and the the top burners light. can someone tell me what the problem could be? i did notice that when I turned on the pre heat I...
The orange glow you see is coming from the oven igniter. The igniter needs to glow white hot in order to light. You need to replace the oven igniter. Hope this helps.
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
