Kenmore Washing Machine won't agitate, spin, or drain
My washing machine quit working. It will not spin or drain and makes a noise when it tries to agitate (it doesn't actually agitate, but moves slightly). We replaced the pump but that did not solve the problem. Any ideas? Thank you!
  • 14 more comments
  • want2know Dec 12, 2007
    You were right -- it was the motor coupling. Thank you so much!
  • RoseWind72 Dec 17, 2007
    My daughter was helping with laundry and forgot to shut the lid. The water filled up and didnt finish the cycle since the lid was still open. Now we cant get the cycle to start or to empty the remaining water.
  • Anonymous Dec 23, 2007
    Washing machine is not draining or agitating and it makes a humming noise. help!
  • Anonymous Jan 08, 2008
    I have the same problem with my Kenmore washer. Fills up, but agitate, does drain water out but not thoroughly. If it is motor coupling, is it hard to replace or can it be done without a service call?
  • Anonymous Mar 07, 2008
    my kenmore front load washer lost the fast spin cycle. my husband replaced the belt and tried new rectifier [ if i get it right], still no effect.
  • Anonymous Apr 23, 2008
    washing machine will not spin or aggitate
  • washingqueen May 18, 2008
    My washing machine only fills up with water and then it wont agitiate, drain or spin. it doesn't make any noise, it just sits there. Its not the coupling, because we just replaced it.
  • Austinsmom53 Jun 21, 2008
    My washer will fill with water but will not aggitate. It makes a noise and kind of smells when it is trying. If I skip the cycle on to "spin" it will drain and spin but it smells like its burning. Help please?
  • kitty rodriguez Aug 11, 2008
    My washing machine will fill and agitate, but will not spin or drain, why would this suddenly happen?
    Washing machine will agitate, but not drain or spin, why?
  • Anonymous Aug 15, 2008
    motor coupling
  • jethro67 Sep 08, 2008
    I have replaced the motor coupling, the old one did not look stripped. When I tested on spin it makes a very loud grinding noise same as before I tried the coupling. hints?
  • sdorris2007 Sep 08, 2008
    My washer is having almost the same problem but it will fill up,it will spin and drain if I spin the dial. It just won't aggitate
  • phillipsfami Jan 24, 2009
    I have a Kenmore direct drive washer that will not agitate or spin. It makes a grinding noise when attempting to agitate or spin.
  • Anonymous Mar 14, 2014
    Machine has started making a squeaking noise when agitating and spinning.
  • Jose Silva Jun 15, 2014
    It makes a noise only when it agitates
  • 51 Answers
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Posted on Dec 07, 2007
In my case, a nylon sock got sucked into the drain pump. I removed it and everything works.
Posted on Oct 17, 2008
There is two little plastic fingers connected by a rubber washer that connects moter to transmission plastic finger broke from overloaded washer
Posted on Apr 29, 2012
2 Suggested Answers
  • 10 Answers
SOURCE: Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Posted on Jun 01, 2009
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
Sep 26, 2014 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 14, 2011 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
Spin cycle doesn't spin clothes dry. machine makes noise when it first starts to agitate but then the noise quits.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 28, 2011 | Washing Machines
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
8,826 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
