Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung lcd tv
I got help from you guys earlier this week but I still have a problem. I was told my problem might be the lamp so I ordered one and put it in. Everything was fine for about 10 minutes, but then the TV's color went all weird and I couldn't shut the set off with it's controls (remote or the button on front). The set is only 3 years old and is a Samsung HLP4663W. Is it the color wheel like somebody else suggested and if so, is that expensive to replace and can i do it? Help!!!
  • jdwpraise Dec 09, 2007
    Thanks for your help. I went online and found a site that showed how to replace the color wheel. The wheel itself is only $96 plus change but to replace it is a major overhaul of the set and I don't feel confident enough to do it. Anyway, I think your right and when the repair shop calls me with the $700 estimate for a $100 part, I'll wish I were more adventuresome...
    Jay
I still can't believe that samsung is not even willing to recall peoples color wheels when almost all customers have been experiencing the same problems from all the reviews i been reading. I have the same TV. and my color wheel is shot as well, I am going to take the tv apart today and attempt to fix the color wheel as i have no intention of dumping more money into this dinosaur of a tv. There is only two moving parts on the color wheel, the motor and the wheel it self which is house on a bearing. i'm going to lubricate the bearing and see if that will at all help as i have heard from samsung techs that the main problem with the color wheel is the insufficient dust barrier as well as cheap bearings used. You would think that after spending 2500.00 dollars it will perform at least more then a year
Posted on Dec 19, 2007
    Scholar:
  • 137 Answers
You have a defective color wheel. Its not easy to change. You must be familiar with the Lite engine. This TV carries 2 types of Color wheel. Look at the side of the TV for your version number to see which one it uses.
(1) Part number BP96-00674A COLOR WHEEL (FOR TYPE L3 VERSION PW03 UNITS)
(2) Part number BP96-01103A COLOR WHEEL FOR TYPE L6 VERSION PU01 UNITS
Best regards
CircuitCity
Posted on Dec 07, 2007
Should I keep giving this guy food?
Ask your boss to talk to hm next time he shows up.
Jan 04, 2017 | Restaurants
My LCD projection tv(KF-50E200A) displays projection lamp week when switched ON and out of red color display on the screen. Is this will happen if the projection lamp is week?
no and yes
the lamp warning is to alert you that a timer has expired that clocks the approximated life of the lamp in "hours of use".
it is never accurate and is dependent on whether or not it was reset the last time a lamp was replaced.
reset the lamp timer in the users "setup" menu.
the lamp has NOTHING to do with color, it only provides light.
check the connections between the TV and cable/satelite box...the red.green.blue component connector...the red one is likely loose.
if this does not correct you color problem, your optical engine has failed.
very expensive repair, not for the DIY type guy.
Apr 17, 2011 | Sony KF42E200 TV
If my samsung dLp HLM 507,has no lights,no power& the lamp is tight in the socket.Could it possibly be the BP-96 lamp? I've heard there's some sign of life when the lamp is bad.this set's dead
90% of the time the lamp is bad when the lamp is bad a lot of the time you will here a buzz sound by the lamp its trying to trun on the lamp but cant. also look at the flashing lites on the front of the tv it should give you code
Dec 08, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
The red and green lights on my Sony KF-42SX300 keep flashing, and the TV will not switch on. It was working fine earlier, the lamp light also comes on, but not all the time, it has noly just started doing...
I would take the Lamp out and see if it is shattered. It is not unusual for them to fail suddenly. If it is shattered, you can contact Sony at 1800-222-SONY and order one.
I hope this helps
Skyassoc
Aug 28, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
My Hitachi 70" LCD will not turn on
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Feb 04, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Light flashes, bulb fires, no LCD!!
Sounds like the ballast is faulty or else your lamp is getting close to needing replacement. Hope this helps.
Jan 16, 2008 | Zenith E44W46LCD 44" Rear Projection...
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
191 people viewed this question
Jerry Greenberg
Jerry Greenberg
