Home | Acer | Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook | Acer Notebook 5610Z - W...
Acer Aspire  5610-4648  PC Notebook
Problem for Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook
Acer Notebook 5610Z - Want XP Drivers
By dburch on Dec 07, 2007
I want to get rid of the present Vista O.S. on
this ACER 5610Z Notebook computer....
Want an easy way to download the appropriate
drivers to use Win XP Professional.
Any suggestions?
Comments:
Dec 08, 2007
- id suggest downloading the drivers for windows xp from the manufacturer onto a usb storage device
I can NOT find the Acer drivers for Windows XP.
I know how to install Windows XP - but the XP drivers are NOT
listed on the Acer Web Site - the drivers listed are for Vista, i.e.:
Microsoft's Monopolized O.S. that renders everyone's old
software useless... If you know where I can download all the Win XP drivers for this Acer model - I would like to know... Thanks...
Clarification Request
Posted by bismin on May 28, 2009
Solution link . . . www.Laptop-Problem-Sollution.com'
Same Problem
Mar 16, 2009
-   Windows Vista is very slow -   nath_bainreb
Feb 07, 2009
-   knowing that vista is a total flaw,i wanted xp on my system.however, i cant get the drivers even on the acer site.
-   emoronu
Jan 23, 2009
-   Cant find drivers for acer5610
-   thiwanka_pei
Jan 15, 2009
-   same problem
-   Guest
Jul 18, 2008
-   need drivers for eterneth for aspire 5610z-   Guest
Best Solution
posted on Dec 08, 2007
Helpful)
gemini14
Rank: Master
Rating: 84%, 35 votes
if your currently able to surf the internet with your vista os id suggest downloading the drivers for windows xp from the manufacturer onto a usb storage device like a thumb drive or external hard drive(hdd).
after you have all the drivers you'll need have:
the windows xp disk.
1)before you restart the computer insert the windows xp disk into the cd-rom
2)resart the computer
3)when the computer starts to post press the appropriate hotkey to enter the bios(usually f1,f2 or delete key) it'll tell you on the splash screen.
4)check the boot order in the bios making sure the cdrom is the first boot device. if it is press f10 to save and let the computer boot.
5)on the upper left of the screen you'll see (boot from cd)press any key(hit a key quickly)
windows xp will then start loading on the computer.
6)windows will look for previous installations of operating systems and display them on the screen
7)click on the partition w/the current os (when you click the os will be highlighted)
8)xp will give you the choice to install delete or format the current partition
9)choose to delete the partition
after you delete the partition windows will show a matrix of the hard drive without partitions (RAW SPACE)
10)highlight the raw space
11)choose create
Comments:
Dec 08, 2007
- 11)choose create partition then proceed with the installation.
windows will automatically format the hard drive and install.
once windows is done installing and you get to a desktop instert the media you have your drivers on.
12)go to my computer
13)right click to properties
14)go to device manager and see if theres any yellow exclaimation points or red x's.
if there is just clik on the device and re-install the drivers
more than likely youll have to re-install your video drivers to get max resolution.
print both sets of instructions.
BEFORE YOU START THIS PROCESS GO INTO THE DEVICE MANAGER IN VISTA AND WRITE DOWN LINE-BY-LINE, EVERYTHING INSTALLED W/MANUFACTURER NAME AND DESCRIPTION
Dec 09, 2007
- here is a link for acer aspire 5610 wireless adapter from there you can download the rest
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4266551
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 20, 2009
Helpful)
xarxasnemo
Rank: Apprentice
Rating: 85%, 1 votes
ddfdas
Was this helpful?
Yes
No
Solution #3
posted on Apr 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
siktir git
Solution #4
posted on Feb 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
All the xp drivers for the 5610z you need at http://mosswalks.blogspot.com/ these are the drivers I rounded up when I switched over to XP. My machine is much faster now.
Solution #5
Helpful)
Aspire5610z
Rank: Apprentice
Rating: 85%, 3 votes
gemini14 your posted solution will NOT work. There is some sort of strange hardware incompatibility with windows XP on this notebook.
I posted about this issue here.
http://forum.notebookreview.com/showthread.php?t=167486
please reply to my thread if you can figure out a way to get XP installed on this notebook, thanks.
Was this helpful?
Yes
No
Solution #6
posted on Jun 22, 2008
Somewhat Helpful)
sfdsdfdfd
Rank: Apprentice
Rating: 82%, 5 votes
im having the same problem with acer xp drivers not working or not being able to be found, i dual booted and i need the driver for the side buttons. Acer offers drivers from thier website but not all of them have xp drivers and little of them actually work. iv been searching for a long time and havent found them yet. i suggest using drivers from diffrent acer models to run them
Was this helpful?
Yes
No
Solution #7
posted on Apr 08, 2008
Somewhat Helpful)
nobe52
Rank: Guru
Rating: 88%, 69 votes
hi there,
if u need drivers for all your hardware go to:-
Was this helpful?
Yes
No
Solution #8
posted on Aug 18, 2009
Not Rated)
ialme
Rank: Master
Rating: 90%, 5 votes
Hi Friends,
Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #9
posted on Mar 01, 2009
Not Rated)
doc_arif
Rank: Apprentice
Rating: 0%, 0 votes
the xp drivers are on this site everything works except the bluetooth driver.
http://support.acer-euro.com/drivers/notebook/as_5610.html
Was this helpful?
Yes
No
Was this helpful?
Yes
No
Solution #11
posted on Dec 30, 2008
Not Rated)
xclancy
Rank: Guru
Rating: 92%, 51 votes
Please click on the below link and this will give u all Windows XP Drivers u need for Acer 5610
http://www.laptops-drivers.com/acer-notebooks/download-acer-aspire-5610-drivers-windows-xp.html
I hope this solves your problem
All the best
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5610-4648 PC
Questions and Unsolved Problems for Acer Aspire 5610-4648 PC
Do you recommend Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook?
Answer
Answer
sometimes when i turn off my acer aspire 5610z it says that the wireless network adapter is not... (More)
Answer
Extensa 5420-5687 Acer Crystal Eye Webcam works but says need to update driver and when I check... (More)
Answer
my Acer Lap model is Aspire 5571AWXMi. Bought it before 3 yrs during its life i could'nt use its... (More)
7 Other Users Have The Same Problem - Continued
Comment by Dewet, posted on Jun 22, 2008
I converted from Vista to to XP but am unable to get hold of all required drivers for Acer Aspire 5610z
Comment by anban, posted on Dec 30, 2007
i want drivers for xp operating system for acer 5610z model
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5610-4648 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
