My hard drive being extremely slow
I have just upgraded my hard drive from a 160 to a 500 gb drive. The only problem is it takes an eternity to load up anything from the drive. What can I do to verify that the drive is working as it should? It has gotten to the point where i have to wait 5 secs for a window to open..
Should I think about returning the unit back to the seller or what?
  • qzam Dec 07, 2007
    Hey there, thanks for the info, but adjusting the VMM doesn't seem to do the trick. I upgraded from an IDE to a SATA drive and it just seems like the computer is always accessing the drive. The little LED is always blinking and it is jsut slowing down the speed soo much. Is there anything else I could add to make this easier to solve? thanks
    Habit-Forming:
  • 115 Answers
I hope it was at least 7200RPM but that wouldn't change with time.
However
You might the files most used are put in a logical order and the whole drive isn't accessed. As you add files to this drive expect the seek time to increse as more records are loaded.
It will take awhile. Then I would adjust your VMM (virtual memory management) located under control panel > system icon. click the advance tab. Slightly different with XP but you are seeking the performance options dialog box then manually adjust the size on the new drive by entering new values click set.
Since your drive is so large you could partition it into 5 drives of about 100MB. This would be the ideal solution.
You did not mention the type IDE, SCSI,PATA,ATA-100, ATA-133 drive you upgraded. Sometimes if you use the old IDE cable you do not gain any enhancements you would expect.
Finally do the math and located your bit Data Transfer Rate on the new drive it will be in MBps 500Gig devided by the MBps will give you how long it will take to read the whole drive. MAX time.
RATE ME IF THIS HELPED
Posted on Dec 07, 2007
  •  Larry
    Larry Dec 08, 2007
    you didn't say if you upgraded the cable!
    Note my comment about IDE cable, if you don't upgrade the cable it won't go any faster than the old ide! Basically think of it as a pipeline, or what happens when you use USB 1.0 cable for USB 2.0. No improvement.
    So look at the cable and up grade if you haven't.
Please does Dell Latitude D600 support Windows 7 especially for the wireless because i am considering upgrading from Windows XP to Windows 7. Thanks
Officially it is not compatible, but I've heard it can work.
However, if you still decide to try, I must warn you:
You'll encounter countless problems with the drivers, which some of you'll have to download manually from the internet. Otherwise some of the features won't work, f.ex the Wi-Fi.
It would be better to leave it be or consider linux.
May 03, 2011 | Dell Latitude D600 Notebook
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Hp 530 laptop is very slow and freezes
Well, The problem can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the hp speed up tool http://www.speeduphp.com/ to give a free & full scan of your slow HP PC to find & fix all possible issues.
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance. But that won't be the most economical way, as you know you can't always afford to do that.
May 08, 2010 | HP 530 Notebook PC
Data saved on Seagate 500 GB eternal drive : how
Assuming the seagate is still working, it would be a simple matter copying the seagate to another hard drive. Need more info for your problem. Operating system, your new drive, in computer case or not.
have you installed a new hard drive, or have a new comp. you want to transfer the data to.
More info will help solve your prob.
Lee
Dec 18, 2009 | Computers & Internet
Slow processing and start up on thinkpad r61
sounds like you have too much data on your hard drive and possibly too much stuff starting up with your computer so use jkdefrag, msconfig, startup control panel and ccleaner to clear and clean up the data on your laptops hard drive.
Use ccleaner first which you can get here
and then defrag your hard drive afterwards using
jkdefrag which is here
msconfig you can access by going to start --> run and type msconfig and press enter or click on ok and then go to the startup tab and stop things running that you dont need to run although using startup control panel which is here would be a lot easier and better as you can check the run keys in the registry as well as the startup and run once keys and make sure only the things you need to run at startup are actually booting up.
Once you have done that see if it is any better and post back
Apr 15, 2009 | Lenovo ThinkPad R61 7743 - Core 2 Duo...
I upgraded the memory from 1Gb to 2 Gb but my laptop's still slow
it can't be, check if the windows is reading 2gb from system under control panel.
to find out if your pc is fast, see if it plays a game faster than before or use a program faster than before
there is no diffrence in using windows itself. example i think in your mind you'd expect to click on my documents and it loads it super fast now with 2gb of ram? no, you're wrong weather you have 1gig or 2gig windows still works the same
the diffrence is Faster file transfer, faster applictions but not a faster windows.
it could also be the norton if you installed, it lowers your speed.
check Task manager, in the performance section
cpu usage should be under 10%
and pf under 500mb
Mar 03, 2009 | Toshiba Satellite M55-S3512 Notebook
File transfer rate is EXTREMELY slow
plz try to format the drive before transfer....
Feb 04, 2009 | Buffalo Technology (USA), INC. - 500GB...
Hi I have a Sony Vaio VGN-S1HP (model PCG-6C1M). It is too slow and running out of hard drive space. I would like to know if I can upgrade the processing power and also increase the hard drive from 40g to...
Well I would recommend upgrading your RAM to 2 GB (Your standard model comes with 1/4 of that) and a 250 GB drive. The RAM would cost you about $80 in parts and perhaps $30 labour and the hard drive should be about $60 in parts and $20 labour. I don't recommend upgrading processors as it can cause warranty problems down the road.
Oct 14, 2008 | Computers & Internet
Loading driver
That is a 10GB hard drive. You don't need any special drivers to use it unless your computer is extremely old.
Jan 14, 2008 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Computers & Internet Logo
310 people viewed this question
Alun Cox
David Payne
David Payne
