Pauldonp need help with tp50f60 light comming on but not powering up
  • scmedrano Dec 07, 2007
    i found a part that looks like a distribtor on a car. when i took one of the plug wires off i noticed that the tip was bent where it couldnot have set in the plug right. could this be the problem? if so how did the tv work before?
    Genius:
  • 1,030 Answers
Sound like the part know as flyback...or high voltage splitter..this can be a problem if this is what i think your describeing... it very simalar to distributer in that it distributes high voltage to the projections tubes
Posted on Dec 07, 2007
  • Willie Howell Dec 07, 2007
    what is your model and make of tv
Why does it keep turning off?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Aug 10, 2015 | Toshiba TP50F60/61 TV
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Mar 02, 2013 | Toshiba TP50F60/61 TV
TP50F60/TP50F61 picture won't come on for long stretches
If you need to hit the tv my money is on a bad solder joint. Re-flow solder on any suspicious joints.
Oct 08, 2012 | Toshiba TP50F60/61 TV
Some time my nokia 6300 phone doesn't switch off
hi i need to know what country your in and what network the phone is locked to is it the code for the sim unlock or is it the master security code that you need let me know as i can help you
Comments: Jan 14, 2008 - by pauldonp - hi ive got the codes for you but the only problem is its giving me 7 different codes to try here are the codes try the first one if this dont work try 7 then 5 then 3 and if still not unlocked pick 2 others to try if you get it wrong 5 times you will need to get the phone unlocked using a cable to computer but you usually get the code in first 3 trys.
to enter code switch phone this is just example but tells you how to enter letters in the code the code will look like #pw000000000000000+1#
to get the p and w after pressing #key to get p press * 3times fast to get w press * 4 times fast and to get + press * twice fast.
if the phone isnt unlocked after 5 trys you will need cable to unlock it after this try puttin different sim card after each try to see if it is unlocked here are the codes......
#pw+986302402445600+1# try 1st
#pw+103074522142176+2#
#pw+855211171344310+3# try 4th
#pw+332326054015123+4#
#pw+345516762307010+5# try 3rd
#pw+396876410470476+6#
#pw+888131400643432+7# try 2nd
try any of the other 3 last getting it wrong 5 times wont lock the phone but you can then only unlock using cable usuall its code number 1 or 7 that will unlock the phone.
Make sure you enter exactly as they are if you need further help let me know ok
Jan 14, 2008 - by pauldonp - code 7 should unlock the phone but try 1 first 7 should unlock the phone to all networks but remember to wait 30 sec or more before entrering codes.
ENTER THE CODES WITH NO SIM CARD IN I FORGOT TO SAY THIS IN LAST MESSAGE
Jan 16, 2008 - by pauldonp - do you have the cable for your phone to plug into your computer you need the flash cable Thanks
Jun 21, 2010 | Nokia 6300 Cellular Phone
Need to replace picture screen, it has cracked in several places. Where do I find one and it is replaceable?
it is replaceable but dont know where you can find it dont know where you live, sorry ( go to a near tv repair shop ) they shoul help you
Dec 16, 2009 | Toshiba TP50F60/61 TV
Tv does not come on.the red light next to the
Count the number of blinks and that is an error code to allow you to diagnose a problem with the TV. Once you are sure about the error code, re-post here asking for what the error code means and how to fix it. Make sure you post the make, model of TV. I hope this helps and good luck!
Dec 03, 2009 | Toshiba TP50F60/61 TV
TP50F60/TP50F61 not working; no picture or sound;
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Toshiba TP50F60/61 TV
Will not power on.
my tv keeos shutting off with red blinking light how do i fix it?
Dec 06, 2008 | Toshiba TZ50V51 50" Rear Projection...
BLINKING POWER LIGHT
Muddy,No,The Problem lay in the Power Supply Delection of your Set Please summit me a Model #
Jul 17, 2007 | Toshiba TP50F60/61 TV
FINDING PARTS
m8 try the tech guys at this site they should be able to find you the part as long as you can provide the seriel no. ect an they should do you a nice price. tell them i told you bout them.i do alot of bussiness threw them so leme know if they look after you m8. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Toshiba TP50F60/61 TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
