Question about Samsung ML 1430 Laser Printer
Samsung ML 1430 - won't print; paper light flashes
When I send a file to the printer, the data light flashes for a moment, then the yellow paper light blinks. Samsung tech support ran me through a number of diagnostics, then concluded it was a hardware problem. It will cost more than the printer is worth to have it looked at and/or repaired at a repair shop. Anyone have an idea what the problem might be and how to fix it?
Shelly
  • 1 more comment
  • witchguy Feb 21, 2008
    Thanks for the help. My printer suddenly started working, even though I had the IT people at the University where I used to work try their hand at fixing it. They are pretty sharp but had no success. The solution may have lay in reloading the driver, which I did, but I'm not sure. Anyway, I filed away your solution and will give it a shot if and when the machine starts acting up again.
  • kilty Mar 23, 2008
    I can't seem to find the proper driver.  I just bought an imac intel with Leopard and it isn't showing in the list of drivers.  Any help would be appreciated.
    lesley.young@rogers.com
  • stsimon Mar 29, 2008
    After upgrading to system 10.3.9, the ML-1430 print driver didn't work, and Samsung no longer offers the driver. So I used Gutenprint, which was super-easy to install, and the printer now shows up in the print dialog box. But, same problem: the print center shows the data being sent, but the printer data light does not blink, even though it will print a demo sheet fine.
    Looks like the solution will be the usual default upgrade route: buy a new printer! Damn.
Tuesday, October 17, 2006 Samsung ML-1430 Won't Feed Paper My printer had stopped feeding paper reliably a while ago. This had reduced me to manually pushing each sheet of paper into the machine until the roller caught it. Which, in turn, often resulted in many explicatives directed towards said printer.
All in all I like the Samsung ML-1430, which has been discontinued. It was pretty inexpensive, the toner cartridges aren't too bad considering I really have gotten thousands of pages (at Staples, which has a wicked good customer loyalty program, IMHO).
However, after only two years, there is this feed problem. I found the answer in an Amazon posting (thank you brs for posting this). Here is the solution from there:
  1. You need to rotate the rubber band on the feeder roll to a fresh surface. Start by turning off the printer, disconnecting it from power & data feed.
  2. Remove the two screws from the back panel and press the small tabs to pull the back panel off.
  3. Open the front of the machine and remove the two screws that hold the top panel in place. Take note of how the sheet feeder sits in this assembly. The sheet feeder is not screwed in, but rather held in by the other pieces.
  4. Remove the toner cartridge and set aside.
  5. There are four screws that go through the metal plate now visible at the top. Leave the wires connected and remove these screws. Take note that there is a grounding cable that needs to be reconnected.
  6. You need to remove that top assembly, so take note of how the roller fits into the black tie rod that actually turns the roller. I found that lifting the unit up and sliding it to the right (as viewed from the back) disconnected the roller from the tie rod.
  7. Remove one screw from the roller pickup assembly and disassemble the roller.
  8. Note that one side of the rubber band is shinier than the other. This is the problem. Carefully work the rubber band off, rotate it 180 degrees and slide it back on to the roller.
  9. Reassemble and test
This repair took less than 20 minutes and I expect that it will last another two years of rather heavy usage.
BTW, brs on Amazon also provided a repair part number: JC72-00109A. However, searching on Samsung for this part yielded nothing. I suspect this is due to the machine being discontinued.
Have fun!
Posted by Peter Degen-Portnoy at 5:44 PM Samsung ML 1430 - won't print; paper light flashes - icon18_email.gif icon18_edit_allbkg.gif Labels: printer, solution, technology 18 comments:
Posted on Feb 21, 2008
The red light then all the other lights flash alternately- nothing will print
• Reset the printer by briefly turning the printer off and back on again.
• If the error persists, contact a service representative.
Sep 14, 2009 | Samsung ML 1430 Laser Printer
Samsung ML 1430
http://degenportnoy.blogspot.com/2006/10/samsung-ml-1430-wont-feed-paper.html
Dec 10, 2007 | Samsung ML 1430 Laser Printer
Can you oil a samsung ml-1430 printer to make it stop squeaking
Yes, lubricate the chrome shaft with light weight oil.
Jul 30, 2009 | Office Equipment & Supplies
How can I print an envelop on a Samsung ML 1430
Put an envelope in the sheet feeder, and use "letters and mailings" option in MS word or whatever program you're using
Jul 26, 2009 | Office Equipment & Supplies
Paper jammimg in our ML 1430 Laser Printer
clean the roller opening the door at the backside of printer...................and if u want our technician support contract us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Samsung ML 1430 Laser Printer
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
How can I make my ML 1430 Samsung laser printer wireless
You need a device called a wireless print server. Some sources are www.tigerdirect.com or www.newegg.com, or you can check pricewatch.com, look for units being sold on eBay.
Feb 18, 2009 | Samsung ML 1430 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
Send doc to printer and the lights all start flashing and won't pring
use the auto clean function : i.e. press the demo button for about 10 sec. until all lights on the release ---- it will automatically clean internally. You can read the manual -- this is a LSU error.
Jan 17, 2008 | Samsung ML 1430 Laser Printer
Samsung ML 1430 Laser Printer Logo
651 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
