"Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly." pops up on my screen when I try to play a file with sound. when not run through Media Player, sound still won't work.
Another problem that happened at the same time is my usb ports won't recognize anything, such as the keyboard. It's light won't even come on. there has been no water or moisture or other damage to the computer.
please help! I have even tried a new keyboard. Nothing I have tried will work. Has anyone else had this problem or know how to fix it? Very frustrating!
Thanks!
SOURCE: need to install new os for motion computing m1400
I suggest Windows XP Pro...
You can open a lot more programs than what you can on Windows Vista with the same amount of RAM etc....
Or you could go for Vista.
Is there a CD Drive does it connect to PC?
I have no idea how to work these.
If it connect's through USB Insert a Windows XP disk into your Drive reboot your PC and install it to remove able Drive.
If you want to ensure that it does not scrub your PC copy then disconnect your PC's Hard Drive.
Sorry if I make no sense I am tired.
Hope it help's.
-Tom.
SOURCE: motion m1400 tablet pc reset bios
My m1400 Can't find operating system and I can't install another xp. It wont boot from my usb cd rom drive, What are my options?
when i download and try to do setup, it says object not present and tells me to restart. i tried it a few times with no luck...
I'm wondering if you were ever able to successfully repair your USB problem.. my M1400 won't recognize anything either, thought the USB port is installing drivers successfully, nothing is detected when plugged in... Any reply will be helpful!
