I have a whirlpool duet the dryer vent was cloged with a birds nest. I cleaned the nest out and vacummed the vent and the vent going into the dryer. I reconnected everything and started the dryer and now it doesn't heat. It turns and the timer works...we also after intially starting the dryer smelled a burning smell. Any ideas?
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
need to replace heating coil. need info on which wires connect to which connection on coil. Duet...
(More)
need to replace heating coil. need info on which wires connect to which connection on coil. Duet dryer GEW9200LW0 serial # MM5065114
does not heat on any setting. opend and pulled out tons of lint but still does not heat. how does...
(More)
does not heat on any setting. opend and pulled out tons of lint but still does not heat. how does one get to the heating element
My Dryer won't start, the controls come on, I have power, the start button is pushed as normal, all...
(More)
My Dryer won't start, the controls come on, I have power, the start button is pushed as normal, all you hear is a click, so I know the relay is activatling. I checked the power, 230 volts, I checked the door switch, I checked the belt switch, there was alot of lint in the motor, I have taken it out and cleaned the lint out of it, I had to replace the motot less than a year ago, they run about 140.00. I am stumped! any ideas? Thank You So Much. Grant
