Question about Goodman GMS90703BXA Heater
GMV951155DXA some times the ig niter wont ignite. the led light is continuously on
  • 1,420 Answers
If the LED is light is on continually it usually indicating a communication error. Check out your thermostat by cycling it a few times. The last and most expensive thing is to replace the circuit board.
Posted on Dec 07, 2007
Whatdoes an oven igniter do as opposed to the oven bake igniter?
Initors work with oven safety valves and open gas safety valves when the amp draw changes as the ignitor heats up. Ig niters light the flame and then become a thermocouple and send back confirmation of ignition to the central control. The model above uses a glow bar ignitor which is wired in series with the oven control and safety valve. The most common mistake when diagnosing the ignitor is working is you see it glowing. But that does not mean it is strong enough to open the bi-metal inside the gas safety valve which requires a minimum of 3.5 amps to bend the bi-metal so it will release gas to the burner. -PawPaw.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2013 | Amana ACF3355 Gas Kitchen Range
Thermostat is calling for heat, combustion air motor starts, HSI glows orange, HSI then stops glowing, repeats procedure 3 times, combustion air motor stops, light blinks once What is my...
Hello, Check to see if you are getting between 40 and 90 ohms on the ig niter, just turn off power to furnace and unplug molex connector at igniter. After u unplug igniter check the Resistance of the ignitor and if it is extremely high like 180 ohms or higher than you will need to replace the igniter.
Feb 10, 2011 | Goodman Heating & Cooling
I need to install a new ignitor switch for my Amana oven. Can you tell me what I need to do.
Hi, What you are going to need to do is remove the drawer and the floor of the oven. Make sure the power is off take the flame spreader out by removing the nut in the middle. then take the 2 screws out holding the old ig-niter. Then from the front reaching through the drawer area un plug the wire harness for the ig-niter. Some generic ignite-rs will require you to cut and splice the wires and join with wire nuts, you can splice into either wire on the ig-niter. once the wires are joined and making sure all wires are tucked to the back re install the new ig-niter with the 2 screws. The put the oven back together in reverse order.
If you have any additional questions please feel free to comment. Mike
Dec 09, 2009 | Amana Kitchen Ranges
Oven doesnt come on most likely its the ignitor but i dont have a meter to ohm it out and dont know the sequence of operation like a furnace cause usually if u have that u know what steps to take to...
Hi, if you don't have an ohms meter the best way to check is fire up the boiler if it works then the problem most likely is with the ig niter. Either the ig-niter will glow or it wont. If it does not glow check it for a crack or evidence of damage. You should see scorching a crack or just basically broken. If it glows check to see what color it glows. Uneven yellowish/orange? it's bad replace it. Even bright yellow to the point where you can't look at it? It may be good. Mike
Dec 02, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven gas was turned off, cannot find where to light pilot again. We have the Frigidaire Fgb24s5dcc Gas wall oven.
Hi, actually this one does not have a pilot, it has an ig-niter part 19. In all likely hood the ig-niter is bad so you should replace it. Mike q51uzbgxsj.gif
Nov 30, 2009 | Frigidaire Ovens
Oven won't heat
Hello, check to see if the ig-niter is working on the oven, this can be done by removing the floor of the oven or removing the drawer at the bottom, If it glows it's likely that the ig-niter is still bad. over time they get old and they do not get hot enough. you should replace the ig-niter. Hope this helps! Mike
Nov 29, 2009 | Whirlpool Kitchen Ranges
Bake on the oven does not work, broil does and the stove top does
Hello, check to see if the ig-niter is working on the oven, this can be done by removing the floor of the oven or removing the drawer at the bottom, If it glows it's likely that the ig-niter is still bad. over time they get old and they do not get hot enough. you should replace the ig-niter. Hope this helps! mike
Nov 02, 2009 | GE Profile JGS968 Gas Kitchen Range
Have a gas stove the range works but the oven will not light
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing it still may be bad. Your ig-niter should glow a brilliant yellow and should ignite the gas within 15 seconds of the valve opening.
here is a link showing pictures of typical ignite rs.
http://images.google.com/images?hl=en&q=ge%20oven%20ignitor&um=1&ie=UTF-8&sa=N&tab=wi
If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Sep 18, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas stove oven ignitor comes on intermttently on it's own,without starting burner
hi thanks for the question did you replace the ig niter if you did not . replace it the igniter does not get hot enough to ignite the gas replace it thanks the appliance doc
Sep 27, 2008 | GE Ovens
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Goodman GMS90703BXA Heater Logo
99 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
