This is a replacement LCD Touchscreen Suiteable BERNINA ARTISTA 200, ARTISTA 730. If your sewing machine is experiencing the problems below, then our ...
Not sure what you are asking. The stitch length will determine how far the feed dogs travel (thus pulling the fabric) to create each stitch. There is also the foot (or knee) control that determines the speed that the machine runs.
I hope you did not pay for it ! IAs a Techie, it is our responsibility to correctly diagnose. If he wasn't sure, it should have been sent to Bernina where it would be fixed!
Its about 700 pounds sterling and should only be changed by a competent person with proper anti-static precautions. When replacing the new board its essential to ensure the display is properly located as its easy to crack if misaligned. Do not overtighten the screws or you'll crack the spacers and when re-fitting the front panel be careful not to trap the high-voltage wires to the fluorescent sewing light (pink and white). Be very careful to make sure the encoder discs on the two rotary controls are properly secured by the little plastic lugs or you'll be really fed-up one day when the control comes of in your hand !!
Ask them to replace the I/O print and make sure its upgraded to the latest firmware, also have them check or replace the motor depending on when you bought your machine these could be under warranty.
Hello. No, the only way you are going to get this to work is to replace the software with new ones, as all software come with different dongle numbers. The dongle numbers are specifically for the software that you have, you can't even change dongles. Can you get in touch with the seller to give you the dongle? I have a set of Cracked software for the BERNINA ARTISTA 180 that I can copy for you for $200, which you don't need a dongle for. Email me on: [email protected] I have a BERNINA ARTISTA 180 as well and this is the software I run. RRP for the VERSION 3 and the CPS software is $4500.00. Thanks. Lawrence
