Question about Uniden Audio Players & Recorders
I cant seem to find an ear bud microphone for my atlantis 250 bk
The input on the 250bk has an inside and an outside thread,i think microphone # hhvta07 might fit,but i want an ear bud set up.the atlantis 250(white radio) is different,it just plugs in and that won't work.any info would be a great help.
Thank you -Gary
SOURCE: how do i change the buds
yeah force it on and applying some kind of lubricant spit is just fine will help as well
Posted on Mar 21, 2008
SOURCE: lost ear phone rubber caps (phillips brand)
You can purchase new rubber caps for Philips earbuds on ebay from seller "auction2world". They are called replacement earbud cap. Unfortunately, you need to purchase the whole set of 3 different sizes.
Posted on Jul 17, 2008
eradiostore
  • 1654 Answers
SOURCE: Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Posted on Dec 08, 2008
  • 17 Answers
SOURCE: only have sound on right side
I don't know if you used new earphones but if you did I would try to clean the inside of the mp3 player then reconnect youre earphone. If you still have the problem return to the store, then the hardware in the mp3 itself is wrong.
Posted on Dec 26, 2008
  • 43 Answers
SOURCE: My XM radio is not functioning properly please help.
Hello Take it to bestbuy and they should be able to tell you whats wrong with it.
Posted on Jan 10, 2009
Alcatel evolve, people can't hear me but I can hear them
Try plugging in ear buds with a built in microphone and call someone to see if they hear you while you speak into the mic. If they can hear you then there must be a problem with the ear bud or head phone input. Some times the connector inside the female plug gets stuck and it fixes itself when you plug a jack into it then pull it out.
Sep 01, 2014 | Cell Phones
Phones get a peersing screach; itgets louder when you press the side where the on/off switch is
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a significant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Dec 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
Severe squelch in left ear phone
The airspace inside the earcup is a tuned chamber defined by the shape of the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs.
If the foam in the ear cushion has weakened/deteriorated to the point that it no longer has it's original shape, (in particular the lower half of the ear cushion), the size and shape of the air chamber inside of the earcup is directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback.
It is probably time to replace the ear cushions. If so, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Aug 29, 2013 | Bose QuietComfort 3 Acoustic Noise...
Hi, when I press the left eatcup close to my ear, there is this very loud high pitch noise that comes from it and is unbareable. I have to removed them inmediately. What can I do, and what those this...
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
Aug 13, 2011 | Bose QuietComfort 3 Acoustic Noise...
Hello, I just got a Bose QC3 on eBay. It works fine except the cable which is not the original one but a one from T'nB and the left earpiece has a very annoying whistling noise when I press it or even...
i would buy a new ear cup.and a new battery. and perhaps a new cord.
i had a problem w/ my ear cups and i noticed that when i bought the new ear cups the sound was better.
i also read that if the battery got alot of usage (4 plus year) then the whistling noise comes from that. i'm starting to have the same problem. i have had my headphones for a long time. i think like anything else that operates on batteries its time to change it.
Mar 06, 2011 | Bose QuietComfort 3 Acoustic Noise...
Where is the mic switch located on my laptop
P000257700 is microphone number and it could be placed in different places depending on the Toshiba series laptop itself, but most probably it is either (A) right above the screen or (B) right in front of the keyboard where you hold your palms while typing with fingers.
There should be a small hole with either "MIC" written besides or some microphone symbol like <<*>>
P.S. You can also plug ear-buds in the microphone socket - it seems strange, but it ear-buds work just like a microphone.
Dec 25, 2010 | Toshiba (P000257700) Microphone
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
Bose QC3 makes a high pitch noise when i press it against my ear
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
My headphones are feedbacking all of a sudden
It may be time to replace the ear cushions. If so, they are available from Bose for around $35/pair.
Mar 24, 2008 | Bose QuietComfort 3 Acoustic Noise...
52 people viewed this question
Top Uniden Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Uniden Audio Player and Recorder Expert? Answer questions, earn points and help others
