Question about GE 32GT740 32" TV
Sound when watching two channels 23 and 43 on my cable the tv loses sound and hisses
  • 934 Answers
It's probably the audio amp Ic, which in that unit is a LA7612n...
Replace that and esr the caps locally and you should be good as new.. Otherwise the hissing will eventually be heard on all channels...
Posted on Dec 07, 2007
We get garbled sound on new sharp aquos +Q TV 60 inch
If you are using an antenna for input, then you are probably partially losing sync with the signal. You may want to adjust the antenna or try a signal booster. If you have input from a cable box, check the HDMI cable, possibly replacing it with a new one. If you're using a cable box with RCA cables, (Composite or component inputs) then the problem is most likely with the cable box loosing sync with the channel feed.
Jan 29, 2015 | Sharp Televison & Video
My tv's freeview wont let me view any other channels apart from the bbc
Freeview? I'm not good with tv words... Is freeview a free channel you stole from the neighbors dish (don't be ashamed)? If so, then you should buy cable (Cable's better. Really. Satellite dish companies looked one thing over. Storms ruin your tv.). If your just watching what you can get through the air, well, that won't work. After a while, you start to lose channels. Just get cable. If you already have a tv network, then you should call the tv company.
Jun 18, 2012 | DMTech DM-AV10 Digital Media Player
Keep loseing local channels , change antenna 4times allways resetting channels gain and lose
Hi, I may have the answer for you. Your (TV) is very sensative to off air stations (anntena).
If you are near a cell tower or Power lines your TV tuner will have a harder time finding anything.
You may need to switch to Cable or dish to recieve anything worth watching. Most off air channels
will fade away because of DTV. If you have a chance Google (digital TV) for your search.
Good luck...
Jun 04, 2011 | Televison & Video
I lose volume on HD channels with Directv
Reset the Directv box,by unplug it,replug it and hour later to let the last software to update.Replaced the HDMI cable,goto ur tv menu,goto sound functions,go down to reset it back to the factory setting.After this the the sound functions should be stable,and work.Not,than ur Tuner signal board have some kind of intermittion short in the board.Than must replaced the Tuner board to solved this problems.
Apr 16, 2010 | Samsung LNT3242H Television
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Lose sound on sony bravia 40v4100 lcd tv
if you are using an hd cable box it might be just that. what happens is if the cable company is doing work around your area or some one on your block adds another cable line to there house you end up losing signal for your box. now if you pull the power plugg and let it reboot that could either fix the problem temporarly or not at all. you might need an amplifier hooked up to your cable lines or a new cable box all together. contact your cable provider and ask for some one to test your signal quality. i am also assuming that your not getting the same problem when your watching a dvd. i hope this helps you
Jan 26, 2009 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Playing vcr causes new digital tv to lose saved channels
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
Dec 01, 2008 | Vizio L37 Television
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
No Sound Issues
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
Oct 13, 2008 | Sony KV-32FS13 TV
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
