Question about HP LaserJet 2550L Printer
HP 2550L Printing Problem
My 2550L printer is no longer printing. It said I needed to replace the magneta toner which I do and did and now when it calibrates it makes a thumping sound and it will not print and if it does print is prints on the left side with a fading effect occuring not even 1/4 into the page.
  • 8 more comments
  • Anonymous Dec 15, 2007
    same problem!
  • Anonymous Feb 01, 2008
    I have EXACTLY the same problem, except I replaced all of my cartridges!! GRRR.
  • belle100 Jun 11, 2008
    Similiar problem, if not exactly the same. I replaced the magenta and cyan toners, and the printer printed a test page fine. It doesn't acknowledge any print commands from my computer. A green light is on, but not the green light above the big green button.
  • Anonymous Oct 14, 2008
    On my
  • pschulz Oct 14, 2008
    On my HP laserjet 2550 all 4 cartridge lights are blinking, and I can't print. The cartidges are faily new, and original HP parts. The printer also makes a thumping / grinding noise when trying to print. When I open the cover, it looks like the cartridges are not turned in the right position ( can't take them out).
  • al56484 Jan 03, 2009
    I have vertical light lines going through my documents for my HP 2550....Its seems to be darker over the color images or a light grey scale
  • Anonymous Jan 16, 2009
    dirver problem find file hpbf3820dl
  • jerm01 Feb 11, 2009
    Same issue. Replaced drum, no change.
  • Anonymous May 08, 2009
    I replaced a cartridge and all 4 lights are flashing.
  • crystal409 May 11, 2010
    Thank you! But do you know what a fewizer is. Am I saying that right they said it help the printer run.
    President:
  • 4,402 Answers
Check to be sure you tool the strip out and that it's seated correctly
all the way down.
Posted on Sep 03, 2008
Magneta Color (Toner) and when I print, the Magneta color does not print. Even on supplies status page, the yellow color section at the bottom is blank where the yellow color should be printed. How c
The Magenta or RED toner cartridge should be removed and double check that you have indeed removed the pull tab located on the side of the cartridge which will remove the sealing tape off the new toner cartridge.
The YELLOW toner cartridge on the other hand if it is not new then it is perhaps empty and needs to be replaced. Another option is to remove the YELLOW toner cartridge from the machine, Tap it and shake it side to side to loosen the toner that is in it, and replace it back into the machine, this will usually make it start to work again!
Good Luck!
Rich Lilja
Aug 31, 2014 | HP LaserJet 2840 Printer
HP Color LaserJet 2550L. Missing colors
The main circuit board is faulty and needs to be replaced.
Feb 27, 2014 | HP LaserJet 2550L Printer
HP 2550 L ...When I try printing in color...........I get red/magenta spots on the printout........why is this happening ?
Are the spots in a uniform pattern? Try the Magenta toner cartridge first, the try replacing the imaging unit.
Jun 26, 2011 | HP LaserJet 2550L Printer
Is my 2550L toast????.
The HP 2550 does take a while to print. It calibrates through all the cartridges & then you'll see your print soon after. You probably need your printer professionally cleaned out with a toner vacuum, the squeaking could be coming from the drum or a pick up roller.
Jul 02, 2009 | HP LaserJet 2550L Printer
HP 2550L printer
Theblack print cartridge is empty or missing. The black-print-cartridgelight is blinking, and then printer stops printing. An error 40208 iswritten to the event log. The printer cannot detect the print cartridgecorrectly. Action
  1. Reinsert or replace the print cartridge.
  2. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Mar 24, 2009 | HP LaserJet 2550L Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
HP 2550L low yellow toner -- can i still print just black???
Unfortunately if one colour is out, then you cant print. These cartridges contain a chip and once depleted will not print until a new cartridges is installed
Dec 12, 2008 | HP LaserJet 2550L Printer
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
My 2550L stopped printing.
take it out and then put it back in.
Nov 05, 2007 | HP LaserJet 2550L Printer
HP LaserJet 2550L Printer Logo
784 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
