Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
From a server I don't go through now
I used to be with quest but now am with a diff. server -- will the adapter still work and how do I switch it over if not?
  • 4 Answers
Is your new server also a DSL server? If you're now using a different service (e.g. cable or satellite) then the Qwest modem will not work at all and is basically an expensive brick.
Otherwise...
Your best bet is to contact your new ISP and find out. Some local ISPs (particularly in Montana) are essentially resellers for Qwest or another national company. If this is the case, the tech support from that company can likely walk you through inputting your new credentials.
If the new company doesn't use Qwest, it will be difficult. From what I've seen of Qwest's modems, they're heavily customized towards Qwest's services. But it is possible, you just need to talk to your ISP.
Posted on Dec 07, 2007
Http 192 168
If you are trying to access the DVR server from outside your network, you need to use port forward, in that way you will use your DVR client to connect to the router's public IP, the router will be forwarding the port the video system use to the computer, just configure the computer's IP in the router's port forwarding configuration.
May 18, 2013 | Cisco Model EPC3925 8x4 Eurodocsis 3.0...
Unable to connect to server playing titan quest
The server is either down, or you have been banned, I own a hosting company and have servers with 99.9% uptime guaranteed http://atlantichost.net
May 22, 2012 | THQ Titan Quest: Immortal Throne for...
1999 nissan quest power window, seat and lock don't work can't find fuse or switch. Any one know which one it is?
My power window fuse don't work. the window goes down never came up
Any one can help me de to it please ?
Jun 25, 2010 | 1999 Nissan Quest
2001 nissan quest front blower does not work on two lowest speeds.
Change your blower motor Resistor...it's probaly oxidized on those two coils....
Dec 04, 2009 | 2001 Nissan Quest
Ps2 console reconizes adapter but wont connect tried adapted in diff machines and worked fine so i knoiw its not adapter also my switch sees ps2 when connected
Its a problem with the main board, if your adapter works in another machine but not yours, then it has to be the main board that is bad.
Aug 07, 2009 | Sony PlayStation 2 (PS2) Console
Slow lan (file transfert) with zyxel ES116P and HP ML150 server
Try forcing the ports that the server connects to on the switch to 100Mb Full duplex, sometimes one side negotiates incorrectly, and the switch can set itself to half duplex, even though the other end is set to full duplex.
Feb 17, 2009 | Computers & Internet
No video, but PS2 mouse + keyboard works
Try finding an adapter for it. You'll need a 12v DC 1 A adapter. I plugged one in and got video right away.
Don't be fooled that it lights up when you plug it into a server. You do need the adapter.
Jan 09, 2009 | Belkin OmniView Pro 8 Port KVM Switch
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
Garmin quest won't swith on.
The Quest charges on about 5 volts you have to plug the cigarette adapter into a 12 volt souce, the adapter then converts it to 5 volts. If you splice 12 volts directly into the mount the quest will not work because you burn up the circuits or the battery.
Sep 11, 2008 | Garmin Quest GPS Receiver
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
109 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
