Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Handycam suddenly won't turn off.
By costuros on Sep 01, 2009
Handycam suddenly won't turn off. When I remove the battery it turns off ,of course, but when I reinstall the battery it starts up even though it is on off. If I try to record it won't and a C:13:01 shows up on the upper right hand of the screen and is flashing. Window shows 103 minutes of battery power left. It wants to stay in photo mode and won't stay in video mode. It will take photos but it won't video. Basically the on/off/mode ring is not working. Can you help? Thanks, Mike
Comments:
Sep 06, 2009
- Thank you, It is a DCR-SR42 Sony Handtcam. I've narrowed down the problem. The ring that allows you to turn it on and off and switch modes is not functional. It won't turn on or off and is stuck in picture mode rather than video mode. I can get it to turn on by disconnecting the battery and re conecting it. It then turns on but won't change to video mode. It will take photos bur I need it to video as we are on vacation in Glacier National Park. Help me please. Mike
Sep 07, 2009
- when I open the LCD housing there is a reset button on the camera. When I push the button, it resets and takes me to "area set" which asks me to pick the country I am in. You say to remove the LCD and press another reset button. I can't figure out how to remove the LCD in order to reveal a second reset button. Help, Mike
Sep 07, 2009
- DCR SR42 Sony Handicam 30 GB Hard disk drive There is no memory stick in the slot. Mike
Sep 09, 2009
- The model number is DCR-SR42 It has a hard disk drive and so it doesn't use a memory stick. Thanks, Mike
Sep 09, 2009
- My Handycam DCR-SR42 is able to play what we have recorded it just won't record anything more and won't turn on and off as it is stuck in photo mode. I have tried the reset button to no avail. It may need a new switch control block.
Solution #1
posted on Sep 07, 2009
Very Helpful)
Ekse
Rank: Guru
Rating: 88%, 4888 votes
Could you post the model of your sony.
Seems to be a Memory Stick Error. Take the memory stick out of the camcorder, and clean the contacts.
Take any lead pencil. Take the eraser and rub it on the gold contacts on the memory stick as if you are erasing writing on paper. Do this for about 30 seconds or more until you get all the gold contacts clean.
Put the stick back in the camera and see if the error message is gone.
If the message remains turn off the camera switch to 'Setup', then turn the camera on. The 'C:13:01' error should disappear. At this point, quickly format the memory stick using the camera's format feature.
Comments:
Sep 09, 2009
- I'm sorry, in my last message, I was only able to see your very first message posted on 1st.
I suspect the issue is a hardware problem, as the error code is related to memory, and your unable to switch to video mode. But photo mode works? that goes to a memory stick or a memory card?
Does the hard drive appear to be working? can you plug it to a computer and can you get content from the hard drive?
Sep 09, 2009
- Had a small mistype there -" I suspect the issue is a hardware problem " what I ment was - a hard drive problem.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 01, 2009
Very Helpful)
welcomejee
Rank: Guru  Cameras & Camcorders  Expert
Rating: 89%, 3239 votes
I think it is Sony handycam but not sure what model it is.
Please provide model number to find out helpful info for you.
Model number would be written on sticker pasted at bottom of camcorder.
Thanks.
Comments:
Sep 06, 2009
First of all, press RESET button located under LCD housing, pull out LCD and press RESET button there to set camcorder on default settings.
If that does not fix problem then camcorder requires to replace Switch Control block (it includes power switch on-off dial too) by qualified camera tech.
I can provide you required part number and where it is available info, if need that.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
I'm looking for good digital camera
Answer
I am thinking about buying a Nikon L100 camera. I would like to know what others think about the... (More)
Answer
i cannot download pictuers , computer is not recocnizing the camera
Answer
when switching on camera lens extends noisily and then retracts and turns off.
Answer
when pictures are downloaded onto computer they come out very blue coloured
Describe your Digital Cameras problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
