Nokia 6600 Cellular Phone
Problem for Nokia 6600
Nokia 6600 Bluetooth, gallery problem.
By azgardezi on Dec 07, 2007
Hi
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow. Any soluutions?
Comments:
Dec 07, 2007
- and i have formatted the phone using the three key 3,* and send .. still it doesnt help
Dec 07, 2007
- I click the bluetooth and it doesnt show an options page. When i exit it after a few seconds a messge comes Btui application closed.
Same Problem
Apr 27, 2009
-   nokia 6600 blue, gallery not open. -   jabajero
Feb 16, 2009
-   sir i have a bluetooth and gallery problem.-   crazysuman
Jan 13, 2009
-   same problem gallery can not open.....
koi hal btao is ka my id = Faiktalat@yahoo.com
-   Guest
Jan 12, 2009
-   my 6600 phone not working
1.file manager not opening
2.my blue tooth not working
3.my phone is very slow.
pl z give me the best solution.thanks
-   Guest
Dec 12, 2008
-   my nokia 6600 phone gallery not opened -   Guest
Best Solution
posted on Feb 07, 2008
Very Helpful)
coolvikki20
Rank: Master
Rating: 80%, 17 votes
Format the cell phone using *#7370#....if ur cell is slow....change the log duration to 1 day.....u can see an instant change in the speed
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 07, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this correct solution is to to change bluetooth modulor its about 600/- cost , if not rehot the BT iC it will work for few months all the best
kumar_ptp@rediffmail.com
Solution #3
posted on Dec 07, 2007
Somewhat Helpful)
zaids
Rank: Wiz  Nokia Expert
Rating: 81%, 569 votes
ok format your phone using *#7370# after that if it doesnt work your bluetooth IC ic is faulty.
Was this helpful?
Yes
No
Solution #4
posted on Apr 27, 2009
Very Helpful)
ollil
Rank: Master
Rating: 97%, 18 votes
FIND YOUR SOLUTION FROM NOKIA.
HERE IS YOUR SOLUTION
www.nokia.com/6600/prob234ei32/solution
Thanks
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Oct 19, 2008
Very Helpful)
jaytony21
Rank: Apprentice
Rating: 100%, 1 votes
no blutooth
Was this helpful?
Yes
No
Solution #6
posted on Jun 08, 2008
Helpful)
saggy 1
Rank: Apprentice
Rating: 92%, 3 votes
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Was this helpful?
Yes
No
Solution #7
posted on May 03, 2009
Somewhat Helpful)
teroc
Rank: Master
Rating: 92%, 15 votes
Hi Friends,
Having problem with Nokia 6600? Don't Worry. There is a site where you can easily fix your problem.
Mainly Nokia 6600 problem is for Unlock CodePuk Code and other Lock Codes. If you are searching for such codes you Must Click Here.
There are also some problem with Nokia 6600. Such as software problemhardware problem etc. If you having these problem you can Click Here. May you find your solution.
Was this helpful?
Yes
No
Solution #8
posted on Aug 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
rehit ur bluetooth ic...it will fix u'r problem
Solution #9
posted on May 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format...
Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
Solution #10
posted on Feb 14, 2008
Not Rated)
redzwan
Rank: Apprentice
Rating: 0%, 0 votes
same problem gallery can not open.......
Was this helpful?
Yes
No
Popular Solutions for Nokia 6600 Cellular Phone
Questions and Unsolved Problems for Nokia 6600 Cellular Phone
Do you recommend Nokia 6600?
Answer
Answer
Hello, anybody help me plz, my x-plore 1.3 s/n 358247037307910, plz give me unlock key
Answer
My Nokia 6600 fold button to open the phone does not work, even when the battery is fully charged.... (More)
Answer
Give me Ultra MP3 license key for NOKIA 6600 my IMEI NO. 353766005237051
Answer
what my personal license key.. my imei is 355664008445599.
30 Other Users Have The Same Problem - Continued
Comment by kinikilig, posted on Dec 11, 2008
please help me..
my blue tooth is not working its sad "teporary over load"
and the gallery is not open..
please help me
Comment by smartprabodh, posted on Dec 10, 2008
i format my 6600 phone by useing 3 pressing keys, then i think my bluetooth will not work plz help me.
Comment by Guest, posted on Dec 05, 2008
6600
Comment by Guest, posted on Aug 21, 2008
why does my n6600 phone gallery doesnt work?how could i solve this problem if i have tried to format and reprogram my phone?
Comment by Guest, posted on Aug 18, 2008
yes me too...what can i do now?
please help me....
if any information contact me pleaseee.....
Comment by mustanp2000, posted on Jun 29, 2008
i have the same problem
Comment by Indermani, posted on Jun 02, 2008
Hi
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth is not working and I shoot some photos then it says temporary overload. Other than that the speed of my phone is very slow. Any solutions?
IMS
Comment by lil diagne, posted on May 22, 2008
i have the same problem. please help
Comment by Guest, posted on Apr 06, 2008
Comment by Guest, posted on Apr 04, 2008
bluetooth problem
Comment by muzahir, posted on Apr 03, 2008
Hi
Comment by Guest, posted on Mar 26, 2008
same problem ...btui app closed
Comment by Guest, posted on Mar 21, 2008
hi my problem is nokia 6600 bluetooth and gallery problem is not opening and system err
please soulation me
Comment by sammy_angel, posted on Mar 15, 2008
same problem please e mail me.
Comment by jstone2u4, posted on Mar 07, 2008
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options.The broswer also does not load. Other than that the speed of my phone is very slow. Any soluutions?
Comment by ananta, posted on Feb 27, 2008
i have also format my mobiel too. evey time i do format it open once. but i cannot get solution. so plz help me.
Comment by Guest, posted on Feb 27, 2008
SAME
Comment by makshr, posted on Feb 26, 2008
Hi
same problem,
bluetooth ("system Error")
Gallery message (opening)
Any soluutions email me - makshr@gmail.com
Comment by Guest, posted on Feb 14, 2008
galley can not open
Comment by Guest, posted on Feb 13, 2008
low ring
Comment by chandima, posted on Feb 13, 2008
my nokia 6600 phone bluetoohdoes notworking
Comment by Guest, posted on Feb 12, 2008
galary does not oppening
Comment by manofsteel27, posted on Feb 07, 2008
i have also the same problem i already formated using the 3 keys ..3 # n call, n also #*7380#, but still doesnt work?
Comment by gurugulab, posted on Feb 05, 2008
hi ,i have the same problem..i click on gallery it shows opening only...n when i click on bluetooth it shows no connection..,
Comment by Guest, posted on Dec 11, 2007
so how can i fix this bluetooth problem i have reprogram it the bluetoohth chip is replaced so how can i fix this..
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
