Question about Samsung RS2534 Side by Side Refrigerator
Samsung RS253BASB SidebySide Fridge Not being Cooled
My Freezer seem to work great 0degree F, but Fridge temp fluctuates between 34-50 F. The temperature gauge that i've put in always says 45 F
Another funny thing is that the Fresh Veggie bin is very cold...freezing veggies inside.
I ran the self diag by pressing PowerFreeze and PowerCool buttons at the same time and it says PLC(power line communication) Error (PLC Related wire cut, Defective PLC module, Defective Communication Components in main PCB) is the description of the test result. (service manual)
Please help
thank you
  • Yuniverse Dec 08, 2007
    tstat? can you tell me what that is?
    I'm not sure where to go from here
    help!
  • 290 Answers
Your fridge has seperate evaporators for the fridge and freezer sections with a variable speed compressor.
The diagnostic test is telling you that the main control board (PCB) is not communicating properly with the display board where you set the temps, or it is not sensing the condition of the fridge properly, either the fan speed or thermistor resistence.
I do not have a manual in front of me so I can't guide you directly, but look in the manual you have and find the tests for the fridge thermistor and fridge fan motor and follow those instructions. If they are correct according to the manual, you probably need to replace the PCB (PBA in parts diagram) located behind the machine inside the compressor compartment, or possibly the user control board which is the the display board that you use to set the temps.
The service manual you have should give tests for the display board as well, but my bet is the main board in the back.
Thanks/Mike
Posted on Dec 08, 2007
  • Michael  Lindley
    Michael Lindley Dec 08, 2007
    Also, the PLC module is the display/input board.
    Mike
    Sergeant:
    Champion:
  • 298 Answers
Probably bad fridge tstat sensing bulb (tstat)
possibly bad open heater in area of fresh vegetable bin
or damper assy not set correctly
  • Eugene Merritt Dec 08, 2007
    Tstat lis thermostat,thermostat has a sensing bulb senses the temperature in the evaporator
    heater is activated by defrost timer to prevent frost or ice
    buildup, If you are lost at this time I suggest you cotact a
    service technician because these items have to tested
    with electronic testiing devices and require partial
    disaaembly of the refrigerator
Top freezer is getting cooled but bottom freezer is not getting chilled
Check freezer fan behind freezer is working. Check ice formation not abstracting the fan by working. This is the common problem- defrost failure. Check thermostat,timer and freezer heater are working.
Simple way of solution. Unplug fridge for some times and after defrost completely, restart the unit.Keep freezer temp @5 degree.
Jan 30, 2011 | Samsung Refrigerators
I have the same problem on my Samsung fridge (RS253BASB). I just had warranty work done, they put in a new evaporator two days ago, and now the outside of the freezer wall and the inside divider between...
It sounds unrelated to the evaporator change unless they were working behind the unit. The evaporator is in the freezer. I think you're having a condenser fan problem which is around back behind the cardboard cover. It should be running when the compressor runs.
If the clicking is coming from the electronic control then it is the problem. It controls the fans and defrost etc. It's part 27 on this diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172308&diagram_id=1356019#d1356019
Aug 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
Have a GE sidebyside REfrig. About once a week
The fan motor is not working properly, call a tech and let he decide otherwise check if your fridge have main control board, that can be other issue
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
http://safemanuals.com/zearchres_663.php
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Samsung RS2534 Side by Side Refrigerator Logo
1,189 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
