Question about GE WBSR3140DW Top Load Washer
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
I turn on the washer with the lid on so the water starts to fill up. Then i add liquid detergent. While the water is filling up, I close the lid and instantly the spinning starts and the water is still filling up. When i try to stop it, it does not stop. I have to open the lid to stop the wash cycle.
Also the SPIN cycle, take a very very long time to complete
Also when i power is off by pulling the plug and putting the plug it, it makes a Continous noise (a tone)
Can someone help me out as to why this is happenning.
Thanks
  • Anonymous Mar 20, 2014
    There is water but it won't spin. Continues to indicate "spin."
    Problem Solver:
  • 7 Answers
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Posted on Dec 22, 2007
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
WASHER FILLS AND AGITATES, BUT THEN STOPS, WILL NOT DRAIN OR SPIN
It may be a bad lid switch. Cheak with your meter for continuity.And if you need more info let me know.Also how old is the washer for there are 2 differant styles of lid switch dipending on how old the washer is. hope i helped :)
May 18, 2009 | Roper RAX4233PQ Top Load Washer
Washer fills with water and just sets there spin cycle works
The timer is failed in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
160 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
