1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
Take your battery to your local auto parts dealer and they should charge for free..Though, assuming battery is low on acid, you will have to puchase battery acid and fill yourself prior to charge depending on whether you have a sealed battery or a refillable battery..The auto parts store should also let you know if its holding a charge..generally takes 24 hrs (trickle charge) depending on how they charge it. my car battery took 30 min. Refilled my hyosung battery with appropriate battery acid and turned out bad battery. I probably ruined by jumping it off while low on acid.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
{ ... The supplied battery is a Li-ion battery. It charges while in the
camera using the supplied charger. The camera can also use a Duracell
CP1 disposable Li battery, which has the same form factor as the
supplied Li-ion cell. HP claim the Li-ion cell will provide power for
approximately 200 shots under "average" use and 100 shots with
"extensive use of the LCD and flash".
Charge time for the battery using
the supplied charger and in-camera charging is 5-7 hrs for a fully
depleted battery. In the optional docking station, charging takes
2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2
hrs. ... }
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
