Question about Panasonic NN-T990SA Microwave Oven
Shut down Unit usually cuts out after only a few seconds of operation.  After a number of retries, it sometimes continues as programmed.
  • 5 more comments
  • Anonymous Jan 06, 2008
    Unit begins to process but shuts off after 5 seconds. Other functions seem to work.
  • charles1358 Jan 07, 2008
    at any selection, either popcorn or time cook the unit shuts down only after running for 2-3 seconds. The door switch seems ok and the unit display is ok. No errors are displayed on display section.
  • fnieves19 Jan 21, 2008
    I have a Panasonic 1300w Genious, model NN-T790SA, and it's works for five second and shut down.
  • fluffy1 Jan 22, 2008
    have same problem. panasonic tech support recommended circuit breaker off and then on. tries to work again, about 3 seconds and shuts off. clock and lights stay on correctly. this is just out of 5 year warranty.
  • j-bone Feb 21, 2008
    Had the same problem and replaced the magnetron with a new one from Panasonic. It worked a few weeks and now the same thing happens again! There is a sparking/crackling noise that takes place after three seconds but stops if the oven stays on.
  • 1fastneonrt Mar 06, 2008
    I have this same problem. It will run for about 3 seconds with a quick crackling noise and then just die, while still suppling power to the front panel. I have reason to believe that it is the power relay (RY1) that is causing this problem. This relay is what tells the inverter to turn on and if bad will cause the microwave to think that the inverter is bad and shut down.
  • Anonymous Mar 24, 2014
    Hotpoint Microwavemodel #REM25SJ01 shuts off after about 2 seconds. will usually restart sometimes need to unplug & start over.
    Problem Solver:
  • 4 Answers
Had the same problem.
service store replaced the magnetron. $50 to replace. New ones at target were $50 (in california).
it's a 5-year warranty. Note that if you no longer have the
original invoice, there is a tag on the inside of the door edge (to the right) with the mfg date which is good enough to prove date of purchase within 5 years.
Posted on Jan 21, 2008
  • Panasonic Master
  • 9,098 Answers
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
THE THERMAL OVEN WORKS SOMETIMES
FOllow this test and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Nov 08, 2013 | GE Microwave Ovens
Microwave does not complete operation. defaults to 88888
please make this test and fix it. God bless you
  1. ain control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
Oct 27, 2013 | Tappan TMS062E1 Microwave Oven
Emerson microwave model #mwg91111sl shut off during use. It did not trip home breaker. It appears dead. It has shut down temporarily 2x in the past year, but came back and operated normally. This time...
You need an ohm meter. This is probably a magnetron that is overheating. Sometimes a vent can get blocked by a curtain or something similar that gets pulled to the unit when the fan is running, or a bad or slow cooling fan can cause this or a bad magnetron. Be sure to short the high voltage capacitor before you do anything else in there. There should be a thermal fuse on or near the magnetron. Some units have a self resetting 'TCO' or thermal cut out. Some have a one time fuse. Some TCO's fail to reset after cycling a few times. These are usually a 'disc' type and are round , usually about the size (diameter) of a nickle and about 1/2" tall. Check for continuity, you should have zero ohms or resistance.
Sep 19, 2013 | Microwave Ovens
Unit fails when attempting to cook.
see the steps and fix it. God bless you
Jul 12, 2013 | Samsung SMH9187 Microwave Oven
Unit cuts off
see this steps and fix it. God bless you
Power cuts off when starting oven or micro
see the diagram attached and fix it. God bless you
Jul 08, 2013 | Whirlpool RMC275PD Microwave Oven
Ge spacemaker microwave repair manual
see the diagram and fix it. God bless you
Jul 08, 2013 | Microwave Ovens
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
No matter what time i put in it cuts off in 60 seconds on a sharp
This sounds like a bad damper switch or motor. Double check the shut off time....... see if it's actually 59 seconds..
When you unplug the unit from the wall for 2 minutes then plug it bad in, you should be able to faintly hear a motor run for a few seconds. This is the damper motor running. This will verify that the motor is operating.....
Also, check the thermistor.
Sep 08, 2009 | Sharp R-1870 Convection/Microwave Oven
Ran on power for 10 minutes, thought it was on timer.
First, check the fuse usually located above the display, inside the top lid.  You can't see if it's blown, so you must test it for continuity with a meter or self powered test light.  Usually fifteen amp, and of the ceramic variety.  (available at radio shack type places) If the new one blows instantly, it's likely a door switch shorted out.  If it blows after a few seconds, it could be the magnetron gone bad, or internal arcing.  The main transformer will sometimes short out, but that's rare.   Be absolutely careful, should your fingers venture around the magnatron connections down below, as there is high voltage and current that can kill you.  This warning applies even when it's unplugged!
The door switches operate together, so if one slams the door shut it will often blow the fuse with no other damage.  Sometimes the crow-bar switch will sustain damage in the process.  Usually, if the switches click individually, they're good.  If one doesn't click, it'll almost always be shorted.  They're located behind the door catch, inside the unit beside the display board, and a bit hard to access.  You will need to reach past the magnatron for this, so be careful.
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
119 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
