Question about Samsung CLX 3160fn All-In-One Printer
Printer fails to pickup paper out of paper tray
I have tried 20lb. and 24lb lazer paper and when I try to print the paper feeder tries to grab the paper from the tray, the papers moves out of the tray an inch or so and then the printer drops the paper which sets off the beeper/alarm sounds. I have tried several sheet of non-gloss paper and the printer gave me no problems.
  • 3 more comments
  • djbinding Dec 13, 2007
    When paper tray get to within about 25 pieces, the paper begins jamming.
  • cloverdaddy Jan 30, 2008
    My printer is a refurbished model and I have been unable to print anything unless I use the manual feed tray.
  • Sollytg Apr 01, 2008
    I have the same problem, and a good clean of the small white rollers doesn't seem to have helped. Any more suggestions? It is driving me mad!!!
  • Anonymous Apr 18, 2008
    My printer also will not pick up paper & says I have a paper jam. I have opened the back, pulled out the the ink tray, pulled out paper tray, looked everywhere & there definitely no paper jammed in the printer. Any help?
  • Anonymous May 12, 2008
    I have a CLX-3160FN which is about 6 months old (purchased new). From the start it had a problem with paper (of different brands/types) partly feeding through and then jamming. It has gradually got worse and now occurs regularly.
    Novelist:
  • 208 Answers
Use a soapy product suck as fantastic and clean the rubber rollers thoroughly.
They may be getting slick and in need of replacement also
Posted on Dec 07, 2007
  • Rick Kasper Dec 07, 2007
    Sorry, SUCH as fantastic not suck LOL oops
Hp 4005 dn top loading tray not working?
Does it try to feed? From the front panel got to administration>troubleshooting>paper path test and select tray 1 and see if it prints. If it does, you have an issue with either the settings on the printer itself, or the driver installed on the computer. If it fails on self test, but tries to pull paper in then your pickup roller and separation pad in tray 1 will need to be replaced.
Mar 18, 2015 | HP Office Equipment & Supplies
Printer picks several pages at a go instead of one. What can I do?
Riffle the paper a few times prior to putting it in the infeed tray. You might try inverting the paper to see if one side is more prone than the other to the stacking problem.
If you have the luxury of being able to adjust the infeed roller pressure (to accommodate different paper weights), adjust it for your paper weight (20lb, 24lb, 64lb, etc)
Apr 13, 2013 | Epson Stylus Photo Px660
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Constant "load paper in tray" error even when paper is loaded.
Contacted HP CEO, office getting some interest now!
Re bad paper feeder Did not use main tray feeder until now!
Nov 30, 2007 | HP Photosmart 3310 Printer
Canon Pixma Paper feed not feeding!!
Either the pickup roller needs to be replaced,(a maintenance kit) or the tray isn't pushing the paper high enough to grab. Tyr loading a few more pages in the tray and making sure the tray is seated properly. Then try replacing the roller.
Sep 17, 2007 | Canon PIXMA MP830 All-In-One InkJet...
My cannon printer jams
This printer cannot use cheap paper. Make sure you use 20lb #92 paper. I had the same problem till I changed paper. Hope this helps
Dec 07, 2006 | Canon imageCLASS D661 Digital Printer
HP color LaserJet 2550n
Look at your printer properties and check that you are using the correct tray settings.
Jun 12, 2006 | HP Color LaserJet 2550n printer + HP Color...
Samsung CLX 3160fn All-In-One Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
