Question about Toshiba Satellite A105 Notebook
Dvd/cd rom sometimes the dvd/cd reads and sometimes it doesn't I have a similar problem with reading CDs. I get the error messages: 'Drive is not accessible' 'The request could not be performed because of an I/O device error'. I have a Toshiba laptop using Windows XP and my drive is a MATSHITA DVD-RAM UJ-841S. I can read DVDs. However CDs are not read consistently. I can eventually get the CD to be read but it takes several attempts. I have tried many things to fix the problem. For example--I tried the advice to remove the Upper and Lower Filters from my registry--still having the problem.
Re: dvd/cd rom
Perfect solution! Thanks for the help! By the way, if you happen to be out of alcohol, a Tuck's medicated pad worls just as good.
Posted on Nov 16, 2008
Re: dvd/cd rom
I had the same Problem AND THANKS GOD I SOLVED IT!!!!
just take any smooth handkerchief "i recommenced the one which comes with the sun glasses! " and try to clean the lens and the Disc Tray ...
and the prob solved :D!
Posted on Aug 29, 2008
  • 181 Answers
Re: dvd/cd rom
Frst, try cleaning the lens in the optical drive with isopropyl alcohol using a soft, non-abrasive cotton ball.
If that doesn't work, we can try some high level bus settings in the Device Manager. Let me know!
Posted on Dec 07, 2007
0 characters
3 Points
My cd drive will read cds but wont read as a burner
Not all Inspirons have CD burners (the 4 factory options were CD-ROM, CD-RW, DVD-ROM, and DVD/CD-RW. You can confirm that via Windows Start > Control Panel > System > Hardware > Device Manager and double click on DVD/CD-ROM drives to see what model drive you have, then just Google it to see what it's capable of.
In case you have either a CD-RW type drive or a DVD/ CD-RW drive and it doesn't want to burn CD's , then it's a bad drive.
Sep 08, 2011 | Dell Inspiron 1100 Notebook
Hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Jul 30, 2009 | HP PC Laptops
the same problem of mine is my drive cannot able to read DVD then i make the solution
if you have CD RAM/ROM + DVD ROM then change it to CD/DVD RAM because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Toshiba Satellite A205-S5804 Notebook
Cd rom problem
Try to play different cds from your dvd rom drive.
If all of them does play then i suspected the cd that you had inserted to play is faulty.
If all of the cds doesn't work, re-install your dvd rom driver. If it doesn't still read any cds then your dvd rom drive is faulty.
Note: If machine is under warranty no need to pay for the repairs.
Jun 04, 2009 | Dell Inspiron E1505 Notebook
After I reinstalled my pc, the toshiba dvd-rom (sd-c2502) only plays cds, not dvds.
Try re-installing your the driver for your dvd rom. Then try to put different dvds and check if it can read from your drive. If problem remains, I suspected it's your dvd rom is faulty
Jun 02, 2009 | Dell PC Laptops
I want new laptop to write CDs - spec says DVD-ROM
Thats the spec for yout laptop, if you have the plug-on module then you can write on it.
Optical Storage
  • Type CD-RW / DVD-ROM combo - Plug-in module
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 16x
  • CD / DVD rewrite speed 10x
Good luck
Apr 27, 2009 | IBM ThinkPad T41 Notebook
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
Mar 21, 2009 | Compaq Presario C700T Notebook
Cd/dvd rom not reading
It's likely a laser alignment problem inwhich you will need to replace the hardware. However, I had a similar problem once with a notebook and found out that a tiny bread crumb was near the spindal making the cd in the drive off balance. Check liberally for any debris. Good luck!
Mar 21, 2009 | HP Compaq Presario C700T
Dvd rom not reading dvd while reading cd properly!!!
The demands on the drive differ greatly for reading CDs & DVDs.
This is a common problem since alignment of the drive is very critical for DVDs and often fails first.
I don't offer much hope, but you might buy a special disk for cleaning optical drives; sometimes they will help.
This article has some tips that might be of use:
Aug 03, 2008 | Toshiba Satellite A135-S4527 Notebook
DVDRW will not read CDs
1)right clik on my computer
go to
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | PC Laptops
Toshiba Satellite A105 Notebook Logo
373 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
