Question about Dell W3201C 32 in. LCD Television
32in dell turns off??????
I have the same problem on my 32 in,after having the Tv on for about 3 hours Tv turns off, every 10-20 min. tv turns off. very upset with DELL. , blue light stays on.... what can i do to fix promblem
  • CCarrnDC Feb 09, 2008
    I've had the very same experience, as has nearly everyone who purchased this lemon from Dell.
    Now, where around Washington DC can you get such a thing fixed?
  • recharged Mar 02, 2008
    well i migrated to this issue from having no sound and video with just the power button illuminated. I replaced the power supply with one from an online salvage store and it worked fine for about two hours and then it shut off, turned it back on and then twenty minutes later off again...repeat... need an electronics person to trouble shoot and trace which resistors and or capacitors are overloading.
    anyone??
    phil
  • 233 Answers
Probably It is a bad inverter board or power supply, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
Agora tv switches off after 20 min
my 32in tv some time turns on and some time not, the blue stad bhy light is on. when we do get it on yhe tv only stays on for 20 min and then goes off . please help
Jun 20, 2012 | Mitsubishi WD Televison & Video
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Re above
I have the same problem on my 32 in,after having the Tv on for about 3 hours Tv turns off, every 10-20 min. tv turns off. very upset with DELL. , blue light stays on.... what can i do to fix promblem.......
Oct 28, 2007 | Dell W3201C 32 in. LCD Television
32 in RCA turns on and off
your problem is in system control section or there might be a problem of loose connection in system control.
Sep 20, 2007 | Televison & Video
Sony 32in
This could be one or a combination of problems. Ive seen this to mbe a simple bad solder joint on the horizontal drive transformer, or a componet in the sweep power supply, or a dryed up capacitor in the standby power supply. Unless you know how to check solid state componets ,this is a job for an expert. Sorry couldnt assist you more. Good Luck
Jul 02, 2006 | Sony KV-32S42 32" TV
Dell W3201C 32 in. LCD Television Logo
143 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
