This happens when the connection to the internal battery is loose or if the internal battery is faulty.In a rare case it can also happen if internal memory on circuit board is gone faulty.
To solve this initially open the set and check the battery if the connections are good or not ,if still has problem than replace the battery.it will ask you to set it up once again after you replace the battery.once you set it up after replacing the battery it will work fine.
thanks.
Comments:
Sep 02, 2009
- open the set and you will find a small battery inside.once you remove it,buy the same type from local radioshack shop.
Sep 02, 2009
- A small coin shaped battery usually it is called cmos battery and the number written on it is 2031. ifyou still cannot find it,then try to remove the cable plugged in the board circuit and reconnect it.this will also reset the connection with battery.
When it rings, it rings once or twice and then goes the message that "No one is here to take...
(More)
When it rings, it rings once or twice and then goes the message that "No one is here to take your call". How to change this? I can't get to the phone fast enough to answer it!
phone records greeting but when the phone rings it doesnt answer and ask for a message. Just seems...
(More)
phone records greeting but when the phone rings it doesnt answer and ask for a message. Just seems to disconnect . The phone works good. the on off works ok...caller ID isnt registering either.
When phone rings nothing shows up for called id. Look into manual but does not have any help in this...
(More)
When phone rings nothing shows up for called id. Look into manual but does not have any help in this area
, My answering machine will not work It will go to my voice mail but it just register the call...
(More)
, My answering machine will not work It will go to my voice mail but it just register the call because I do not have voice mail Phone Model 29897 G E 1A
