Question about RCA MM36110 36" TV
Problem with RCA MM36110
My tv shuts off by itself after about 20 minutes then turns back on. If you put a blowing on the back of it then its fine.
  • Ford man Dec 08, 2007
    This is Ford man again, I forgot to put the word fan before blowing in my problem. If you use a fan the tv is fine. But if not it seems like it overheats. I welcome any comments.
ladywinn
  • 5138 Answers
SOURCE: BLOW OUT
Check on your deflection board for open capacitors Green & Gold writing cp150 location number 2200uf 16 v and two 220uf 35 volts.
Posted on Sep 16, 2008
rulds2008
  • 3866 Answers
SOURCE: RCA 2001 P61927
Okay there is something wroung with the frount panel there may be debris in where the button is depressed or seomthing is depressing the button or it may be just going out on you.
1. take off the frount cover and examine the channel up and down make sure its clean and there are no debris.
2. if that does not work replace the controller board aroun $65 bucks.
I do not know your zip code but you can give these folks a shot www.teexp.com you can call and ask how much it would cost to replace this controller even though they might not work in your area they still can give you a price.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 17, 2009
SOURCE: RCA 32V434T TV Turns itself on and off, changes
I had the same problem. Got it to stay on by unplugging the front button pc board while I researched the issue. It seems that the switches on said pc board begin to "leak resistance" and cause all kinds of problems like on/off, color maxes out, as well as other crazy stuff. After calling RCA and getting no help I decided to remove those seven micro-switches off of the board and, wouldn't you know! Everything is ok with the exception of not being able to controll the tv from the tv itself. Small sacrifice for a free fix. All tv functions work from the remote. Again, a small sacrifice for a free fix! Just be careful when poking around inside, high-voltage and stuff.
Posted on Aug 24, 2009
SOURCE: rca turns itself off and on and scans thru all the channels
I have an easier solution, First I want to thank those who posted the solution that the problem is on the small switch board mounted right behind the switches under the picture tube. I figured that might be where the problem was but it's better to to see it confirmed. I thought the problem was more complex like maybe an IC chip got zapped or something but there are none on that board. Only 6 switches, the infared sensor, 1 capacitor and some resistors. I am convinced that in my case at least the problem is caused by humidity. It happened last year constantly durring humid weather in the summer and only a couple of times over the winter when the air is dry and cooler. I did figure an easier way to disconnect all the switches without unsoldering. After you remove the board, flip it over to the solder side and see where the wires connect. You will see them labled GND - KEY - +5 v - LED and IR. The one you want is labled KEY. You will see on the other side this wire is second from the end . Just separate the wires a bit and cut it. That's it. Just be sure it is the one marked KEY. This wire goes thru a series of resistors and the switches and nothing else. Just cut that one wire and put a piece of tape over the cut ends and thats it. it's a lot easier then unsoldering all 6 switches. And if you do decide at some point later to replace the switches, it's easy to resolder the wires and tape it. I did it this way and my TV is working perfect. I was done in ten minutes. You can only control the TV with the remote but so what, thats all we use 95% of the time anyway. I hope this helped you.
Posted on Sep 05, 2009
  • 14 Answers
SOURCE: RCA D52W20 TV powers on fine, then shuts itself
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Posted on Jan 22, 2010
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
BLOW OUT
Sep 16, 2008 | RCA HD56W66 56" HDTV
Connect MM36110 to Directv HD Receiver
Use both VGA cable where require,the rest use HDMI cables
Aug 17, 2008 | RCA MM36110 36" TV
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
RCA MM36110 36" TV Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
