Mobile Dock backward compatibility Over the past few years I have accumulated a mix of both Mobile Dock PMD-96i-IDE Ultra 100 and PMD-96i-IDE 133 kits. There is no identifier on the products to tell me which ones were sold for a UDMA of 100 or a UDMA of 133. The manufacturer claims backward compatibility. My question is, if I put a UDMA 133 HDD in a Mobile Dock PMD-96i-IDE Ultra 100 drive tray and run it on a 133Mhz bus, will it slow my drive down?. Thanks, Kurt Bohan CalHybrid@aol.com
  • 145 Answers
I would suspect it would work, but only at 100mhz instead of 133.
Posted on Feb 13, 2008
Manual for ASU-T102H-DR-GR
https://www.asus.com/ca-en/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
ASUS Transformer Book T100HA. Overview · Specifications · Gallery ... Description, User's Manual for Simplified Chinese Edition. File Size, 6.83 MBytesupdate ...
Manual & Document - Asus
https://www.asus.com/us/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
There are 3 download servers available on ASUS Download Site - Global, China and P2P. Each server provides exact the same content no matter where you ...
ASUS Transformer Mini T102HA ' 2-in-1 PCs ' ASUS Global
https://www.asus.com/2-in-1-PCs/ASUS-Transformer-Mini-T102HA/
  1. Cached
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a less-than-800g ...
[PDF]Manuale utente (e-Manual) - Asus
dlcdnet.asus.com/.../ASUS/.../T102HA/0410_I11845_T102HA_V3... - Translate this page Jul 25, 2016 - ASUS Tablet e ASUS Mobile Dock e-Manual. INFORMAZIONI SUL ...... T102H Mobile Dock, H102H Mobile Dock,. R106H Mobile Dock.
asus transformer user manual - YouTube
https://www.youtube.com/watch?v=M33hXCvS4Vc&list=UUy74e...d4uTA...
  1. Cached
Dec 20, 2016 - asus transformer tf101 dock user manual ... asus transformer tf101 keyboard dock manual ... asus transformer pad tf300t owners manual.
Dec 30, 2016 | ASUS Tablets & eReaders
Why wont iphone communicate with the ipod station
Have you made sure that there is no protective case on your iPhone that would be interrupting the connection between the two devices? Have you verified that your device is compatible with the dock? On most of the new ones they require a digital input from the iPod/iPhone which only iPods made in the past few years (2007 or later) can supply. Also try docking your device when the docking station is in standby mode.
Dec 25, 2011 | Philips DCM250 Table Stereo Clock Radio...
What brand name mobile phones are compatable with 2009 ford escape blue tooth?
Any phones that say their blue tooth compatible will work. Most phones that have been made in the past few years are so if you recently bought it then it should work
Apr 22, 2011 | Helio Ocean Cellular Phone
Checked Manual: 1996 chevrolet 3500 6.5 turbo. What is a(PMD)? manual doesnt list it.
Common Problems:
Pump Mounted Driver: Relates to thermal failures. The PMD is screwed to the DS-4 injection pump on the 1994-2001 GM 6.5 diesel utilizing fuel flow to dissipate heat. The injection pump is mounted in the intake valley (a high heat area). The PMD contains two power transistors that should be cooled by proper contact with the injection pump body. If the pump is not precisely machined to make complete contact with the transistors via the silicone thermal gasket and paste, the PMD is improperly installed without the gasket or paste, the PMD is installed off center with the pump body, or corrosion develops on the mounting surface the PMD will overheat. Several companies manufacture an extension harness and heat-sink kits. These allow an owner or their mechanic to relocate the PMD away from the injection pump to a lower heat environment and/or a place that can get more air flow.
Hope helps (remember to rate this answer)
Mar 19, 2011 | Chevrolet 3500 Cars & Trucks
I have Toshiba Laptop L300. It does not install xp . however it easily install Window 7
Probably because you have a SATA Hard Drive. If you want to install WIN XP, you may need to change your hard drive settings. For this go to the BIOS and change to Compatible Mode or IDE or Non SATA. The Reasons that WIN 7 install with no problems is because WIN 7 has already builtIn SATA drivers on it
Nov 18, 2010 | Toshiba Computers & Internet
Can I replace an ultra ATA drive with an EIDE drive?
Yes there are several ways.
1st is there a spare IDE socket on the motherboard?
If not you can get a IDE to SATA convertor thet plugs in the back of the drive. or you can get a convertor for a SATA drive to make it IDE compatable.
Sep 20, 2009 | HP 100GB Ultra ATA/100 EIDE hard drive -...
A6561SMS amibios v 1.7 on MSI 745 Ultra Motherboard does not detect the HD Seagate Barracuda 7200 Ide 160gb. The bios simply won't start. What could be? Are they compatible?
Dear user,
Yes HD is compatible on that motherboard but some problem in your ide of motherboard.
pl check your hard disk to another pc working or not ?
Regards,
Ravindra Shah
May 17, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
My computer restarts before installation completes
GO INTO SAFE MODE REMOVE ALL OLD DRIVERS AND ANYSOFTWARE THAT MAYU CONFLICKS AND RESTART SYSTEM
SAFE MODE MAY ALLOW INSTALLATION OF NEW DRIVERS IF SO DO IT IT WILL HELP YOU ALOT.
IF NOR GOINTO CONTROLL PANEL SELECT NEW SOFTWARE LOAD NEW DRIVERS
CANDYMANGANDY
Jan 27, 2009 | Abit AX8 NVIDIA VIA K8T890 + 8237 Chipset...
Computers & Internet Logo
108 people viewed this question
Alun Cox
David Payne
David Payne
