Question about Canon PIXMA MP830 All-In-One InkJet Printer
Streaky print out from canon Pixma mp830 all in one
I have regular white streaks going thru the page when I print. I have done a clean and prime several times. Any suggestions?
  • 4 more comments
  • JanRo Jan 11, 2008
    I've got the same problem. All ink tanks are at sufficient levels and I've done the nozzle check and print head cleaning. All normal.
  • Anonymous Jan 26, 2008
    Same problem. White lines, that get more pronounced as more of the page is printed. Ruins all photos. No problem when just printing B&W. Have cleaned printhead, changed incks, tried different media, cleaned rollers, algned heads repatedly. Is this just a Canon defect with the printhead? Relatively new printer.
  • Anonymous Apr 22, 2008
    I have the same problem as everyone else, and have tried the same things to resolve the problem as you have, without success. Colour photos are ruined, black and white are fine.
  • persephone Jul 31, 2008
    same flippin problem!
  • Trezise Dec 01, 2008
    Had the same problem- after having this printer for about 2 years w/ little trouble, about every 4th line failed to print. Used a ton of ink trying to clean it all out- putting it onto HIGH print quality fixed it- at least for now.
  • Anonymous Feb 22, 2009
    Parallel vertical lines through pictures - ruins them.
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Posted on Aug 25, 2008
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
Printing sound like it is printing but nothing on page, I did a test page and only the some of the printing worked. The black grid didn't show up
You may need to do a printhead cleaning operation.
Do 2 regular cleaning cycles.
If still not printing clearly, do a deep cleaning cycle.
Feb 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Dark black streak down the middle of the page
sounds like your cartridge is leaking. I'd try replacing the cartridge
Apr 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My MP830 leaves white horizontal bands when printing black & white documents. Color printing seems fine. Pattern 'F' is missing on the print alignment page.
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Nov 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I am running a csss system on a canon mp 190 printer.My problem is that I am getting alot of lines in my prints,this has only started recently.I have cleaned and deep cleaned many many times and I have...
Assuming you have aligned the head to produce the minimum noticeable amount of white streaks and gioven all the cleaning, deep cleaning and alignment you have done there are two conclusions.
1. If the printer has been performing OK and using the same ink supply in the CISS and the actual printed results are OK then simply continue withthe setup as is.
2. If the setup as is is producing unacceptable results then you will have to consider changing the print head for a new one.
Oct 23, 2009 | Canon Office Equipment & Supplies
Leaking Ink Cartridge
You need a shop to clean the extra ink that's coming up on the rollers and install a mylar strip to prevent that in the future. It's the waste ink being forced up thru the exit rollers and getting on the prints.
Sep 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp830 printing paused
GO ONLINE AND TYPE
CANON PIXMA MP830 INKJET PRINTER PAUSE PRINTING
OR
CANON PIXMA MP830 PRINT PUASE
OR
CANON PIXMA MP830 FORUMS USERS GROUP
ROD
Feb 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printhead problems Canon PIXMA MP780
that definitly sounds like it needs to be replace, have you tried using the printhead cleaning utility?
Dec 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
806 people viewed this question
old marine
old marine
