Older Maytag Washing Machine - Top Loading "Heavy Duty" model
Agitator keeps coming loose during wash/spin cycle. What can I do to fix this problem?
  • 4 more comments
  • jetjan Dec 07, 2007
    Thanks for your assistance. I will look at the agitator tomorrow to see if what you've suggested will do the job!
  • jetjan Dec 08, 2007
    I appreciate the advice offered. However, after looking at the agitator, I could not find any place for a set screw - no hole at all. And I could not find any rubber ring either. The agitator seems to just slide down over the splines on the transmission shaft with a "friction fit". I replaced the agitator and used a rubber mallet to pound down on the top of the agitator to perhaps better seat it on the shaft. If this does not work, I may have to order a new agitator.
  • jetjan Jan 27, 2008
    Hello Oceti - and thanks for your follow-up ! There was NO hole for a set screw in the old agitator! My solution was to order a replacement through a local Appliance store.
    The old one was "tourquose" in color and the replacement one is black. The replacement one HAS the Set Screw hole in it - with the set screw supplied. I removed the old one and installed the replacement one, tightened the set screw as instructed, and it is working satisfactorily.
    The machine is probably at least 25 years old.
    Regards,
    Jim
  • Anonymous Mar 18, 2014
    my maytag intellisense mwa 09149 wh washing machine keeps having a red light come up on the control panel and keeps stopping the machine
  • Anonymous Mar 27, 2014
    How do one clean a maytag brovas washing machine!
  • Anonymous Mar 29, 2014
    agitator going very slow, almost as it is grinding.
  • 51 Answers
There is a screw near the base of the agitator. If it is missing replace it with a stainless steel screw. If this is a machine that is older than 25 years, you will have to replace the rubber ring on the agitator shaft.
Posted on Dec 07, 2007
  • Randy Bell
    Randy Bell Dec 08, 2007
    What is the model number of this Maytag? How old is it?
  • Randy Bell
    Randy Bell Jan 26, 2008
    Did you ever find the solution to your agitator problem?
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Jun 03, 2008 | Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Agitator keeps coming off
More than likely the plastic tabs that hold the agitator on are worn or bent to the point where they won't hold securely anymore. It's probably a good idea to go ahead and replace the agitator before it comes off during the wash cycle and damages the washtub.
Jun 07, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
