Question about Pioneer DEH-P6900UB CD Player
Speaker hookup i bought a pair of 6x9 pioneer and i installed it on my deh6900ub. i follow the instructions to use 2 speakers and everything good.. bit i notice a problem, when i hook up both speakers to the white and gray wires as it said to do the sound quality drops ..when i disconect one speaker it plays loud and clean but when the 2 are on the sound drops with little or no quality to it. what is that problem ? can anyone help me cause im ready to send it back .
  • zacxs Dec 06, 2007
    please help
  • 62 Answers
Sounds like 1 of your speakers is fed backwards. this does happen quite often. try reversing the chords from the second speaker. (put grey in white and white in grey) if this doesn't work then theres a short and it should be taken back.
Posted on Dec 07, 2007
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
How to connect 6x9 pioneer speakers
Do you mean the Factory Speaker (Conecters) If you do they will have to be changed, To the same type of connecter that is on the speaker wires that come with the 6x9"s
Dec 05, 2012 | Pioneer Ts-a6974r Car Audio 6"x9 6x9 3-way...
What size speakers are in the doors
  • The factory speakers are 6x9 BUT the magnet on the factory speakers are much smaller than on aftermarket, higher quality 6X9 speaker making it almost certain the window will not roll down after installing an aftermarket 6X9.
  • Most go with a 6X5 because they are a bit smaller and there is a wider variety of them. Where ever you go to purchase that speaker. make sure the measurements are taking real well if going with another 6x9. There is always the option of the factory 6x9 but a nice aftermarket will fit in there so long as you mind the size.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 07, 2011 | 1997 Jeep Grand Cherokee
Is it possible to install 6x9 speakers in a 1999 isuzu rodeo??? if so where?
You could use a spacer and install them in anything.
Most audio accessory stores carry 6x9 spacers in 2"
Jan 03, 2010 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Where to find the enclosures for PIONEER TS-A6872R
get some MDF board and make them.or buy the 6x9 box cover front with a peice of mdf screwed down good where the speaker will go and cut out a 6x8 hole.
Oct 07, 2009 | Pioneer TS-A6872R Car Tweeter
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Replacing factory speakers in a 2-door 97 Cavalier
Just make sure they are the same size as your stock speakers and they should just fit right in no customizing needed. For a 1997 Cavalier it's 4X6 in the front and 6X9 in the rear. Shouldn't be too hard just a couple screws and hooking up the existing wire to your new speakers.
Feb 04, 2009 | Sony Car Audio & Video
Rear deck speaker install
I'm assuming that you have left the original wiring intact? If this is the case then it's a pretty simple thing to do. There should only be 2 cables one for each speaker & each cable will have a positive & negative polarity. Once you have securely fixed the speakers into place (usually screwing into place through the mounting holes provided) you just need to attach the wires to the speakers. If your car has manufacturers plugs on & don't match the speaker ones (quite often the case now) simply cut them off & replace with spade connectors of the right type/size. The most important thing is to get the polarity the same way round for both speakers!If you get them reversed you will NOT get any bass. Also remember with any new speakers they need time to run in & sound their take it easy with the volume control for the first 20hrs or so of play if you want them to sound great & last longer!
Dec 27, 2007 | Pioneer TS-A6962R Car Speaker
Pioneer DEH-P6900UB CD Player Logo
83 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
