Question about Toshiba 43A10 43" Rear Projection Television
Toshiba 43a10 will not line up with colors
My toshiba 43a10 looks 3d, I just moved and my boyfriend accidentally hit the tv off the wall twice. Im thinking this is what may have caused it, I tried aligning them with the controls, but still nothing. It kills my eyes to watch. Is there anything I can do other then pay 210$ for them just to look at it? DO you think I can adjust it myself? Or is it a part that needs replacing? thanks alot,
Meg
Bad Convergence IC's.
Posted on Dec 22, 2007
Why won't my toshiba tv model 43a10 display color
It is by the model number a rear projection tube set--Look to see first if when a DVD etc is played you have color or not (via audio video jacks on rear of set)
If you do the set's color circuit is ok.
If using a box unplug it and wait--plug it back and let the box boot up.
If none of this helps the and the set has no color on all inputs you have some problem in the color or chroma circuit in this set---it is very rare for this to be a circuit problem.
May 28, 2012 | Toshiba Televison & Video
A speaker wire on my Toshiba 43A10 rear projection tv came loose when I wanted to replace the speaker, it fell onto the cuircut board and made a short, tv switches on but no pictute or sound
set has a number of pico fuses (up to 7) that are not glass and look like a small resistor and are usually orange, green in color--all will have marked on top of board amperage which is a easy way to find them--have to test them like any fuse (set unplugged please) as they will look perfect even when bad.
Apr 23, 2012 | Toshiba 43A10 43" Rear Projection...
Picture appears to be 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
My tv looks like it is in 3d and ideas what is wrong with it and can it be fixed thanks matt
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Toshiba 53HX71 53" Rear Projection...
My tv went multi colored take it as it looks like a 3d television
  • Screen looks 3D
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
It's like watching 3d. the color at the bottom is red and blue and doubled
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 01, 2010 | Toshiba 43A10 43" Rear Projection...
Have a model 43A10 toshiba tv, has a purple color at very bottom of screen about inch tall. When i go into the menu, looks like writing is not lined up on the lower options of the menu. and partly up...
you either have a color purity problem or a convergence problem. purity can be effected by electro magnets in power supplys of audio amps and subwoofers too close to the tv
Convergence is the ability of the red green blue to drop on top of each other. can usally be adjusted via remote control. Please claify and repost.
Apr 03, 2009 | Toshiba 43A10 43" Rear Projection...
Toshiba Rear Projection TV
In the videomenu theres an option called convergence. you can shift blue and red color arround the green on, hopefully solving you're problem.
Good Luck
Jul 20, 2008 | Toshiba 43A10 43" Rear Projection...
Toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Toshiba 43A10 43" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
