Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Deletion of programs and applications
Went to delete an entry and all programs and applications were deleted. What can I do?
  • panhia Dec 11, 2007
    I have the same problem too. When I get to my application button, it has nothing in it and I need help on how to restore everything in it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
There is no way of restoring it, however if your have your usb chord you can go on the Texas Instrument web cite and download the applications you want again. GOOD LUCK hope this helps
Posted on Feb 03, 2008
Cannot uninstall Belkin. The uninstall file could not be found
this thing happens when you delete the folder in which your files for the program are stored.
or in case you delete the uninstall.exe file.
the program has already been removed from your hard disk, what remains is just the entry in windows registry.
when you uninstall a program, the registry entry is also deleted, so its recommended to always uninstall the program rather simply deleting the program folder.
Nevermind, in your case you can delete the program folder in case you still have it, and the windows entry can be fixed by any registry fixing software like 'Advance System Optimizer'
Oct 10, 2013 | Computers & Internet
I want remove geniune from my desktob
Microsoft has created an application that checks your Windows operating system to see if the copy of Windows you are using is genuine. If it is not, the application launches a "Genuine Microsoft Software Notification" pop-up alerting you that "This copy of Windows is not genuine." This has a purpose. However, many users have reported being flooded with the pop-up notification even when the copy of Windows they are using is genuine. If this happens to you, you can remove the genuine Microsoft software notification. Note that the instructions below apply to the Windows 7 operating system.
Press "Ctrl"+"Alt"+"Delete." Click on "Start Task Manager." The Windows Task Manager opens. Click on the "Processes" tab. Click on "wgatray.exe" and then click "End Process." Restart your computer. Press F8 continually while your computer is booting. The Advanced Boot Options menu will appear. Click on "Safe Mode" in the Advanced Boot Options menu. Click on the "Start" menu and then click on the "Search Programs and Files" box. Search for and delete the following files: (To delete a file, right-click on the file and select "Delete.") "C:\Windows\System32\WgaTray.exe"
"C:\Windows\System32\dllcache\WgaTray.exe" Click on the "Start" menu and type "regedit" into the "Search Programs and Files" box and press "Enter." The Windows Registry Editor opens. Locate the following registry entry in the Windows Registry Editor and delete it. To delete a registry entry, right-click on it and select "Delete." "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon"
b>
Mar 03, 2013 | Microsoft Office Professional 2007 Full...
Nokia C6-01 How do I delete single dialled or received calls from the Log? I can delete from the dialled screen but the call remains in the Log.
Hello Sinyoro,
In the Call Log eg. Dialed Numbers, highlight the number/contact you want to delete, press "Option" and then select "Delete", this will delete only the selected entry. Make sure you don't press the "Delete All".
Hope this helps.
Thanks.
Jan 01, 2018 | Cell Phones
How remove error STRTDB80.EXE
*First goto "X:\Program Files\Oracle" -> find and run Universal Uninstaller
OR
*Search and Delete all Oracle entries in the registry and then delete "X:\Program Files\Oracle"
Quote: HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Services\EventLog\Application\Oracle.oracle * Delete
X:\Documents and Settings\All Users\Start Menu\Programs\Oracle - OraHome80"
*Start->Run->Services.msc and see if any Oracle services are running then disable it. Then find and delete the services entry from registry:
HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services
Sep 10, 2011 | Microsoft Windows XP Professional SP2
Master reset code
  • Remove any memory cards that are in the phone (MicroSD, SD or MiniSD), and remove the SIM card, if your phone uses one. Make sure the phone is turned on before continuing (if you had to remove the battery to remove the memory card or SIM, turn the phone on).
  • Select "Contacts" from the main screen of your cell phone to access your contacts list. Go through the entire list, selecting each name and deleting the entry. Consult your cell phone manual to find out where the "Delete Entry" option is located in your Contacts menu (if you do not have a manual use the link in "Resources" to download a copy of one for your phone). Typically, when you choose an entry, the option to "Edit" will appear on the screen. Select that and one of the sub-options will be "Delete Entry." Do this for all of the entries in your Contact list.
  • Open your text messaging (SMS) application on your phone. Most phones have an icon you can choose from the main screen to go to the application (where you can compose, send, or read SMS messages). Press your "Menu" key again (or the key under the "Options" choice on the screen), and select "Delete All." Click on the choice to delete both read and unread messages. When you are done, return to the main menu.
  • Delete all of your media files. Go to your music, video, photo and MMS directories, and either use a "Delete All" option from the menu, or individually highlight each file name, select "Edit" and then "Delete" and remove each one.
  • Open your calendar and clear all of the entries. Make, sure when you choose this option from the calendar edit menu, that you check off the option to remove the calendar history as well, so past events are erased.
  • Open your email settings (where you entered your email address originally to receive notifications on your phone of new emails), and delete the email address you registered.
  • Open your notepad program and delete any notes you may have stored in the memory. Do this for any Voice Notes, if your phone offered this function as well.
  • Oct 07, 2010 | Motorola Mobility W220 Cellular Phone
    Windows cannot find file csrcs.exe
    File csrcs.exe is located in the folder C:\Windows\System32.
    Program has no file description. The file is not a Windows system file. The application is loaded during the Windows boot process.
    The program is not visible. It is an unknown file in the Windows folder. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to monitor applications, hide itself, record inputs, manipulate other programs. Therefore the technical security rating is 86% dangerous.
    It simply means, "It is very dangerous"
    Try these steps to remove it.
    Click on START-RUN,
    type regedit (it will open the registry editor)
    Press Ctrl+F
    type "csrcs" (without quotes) and click on Search It'll show you some results, where you'll find "csrcs.exe" delete it immediately.
    Again do the same search you may see "explorer.exe csrcs.exe" , right click then modify and remove the csrcs.exe part (leave the explorer.exe as it is)
    Hurray !!! you have removed csrcs.exe
    Restart your system and see it for yourself
    Don't forget to give feedback
    Sep 05, 2009 | Computers & Internet
    Strtdb80.exe
    OR
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSeT\Servic es\EventLog\Application\Oracle.oracle * Delete
    Regards,
    Mar 27, 2009 | Microsoft Windows XP Professional SP2
    How can i uninstall panasonic videocam suite?
    I had this problem and someone pointed me towards this
    http://www.appdeploy.com/software/detail.asp?id=178735
    I eventually deleted the folder that this string identified, and I was able to re-install the software at long last
    pipster
    Jan 03, 2009 | Panasonic PV-GS500 Camcorder
    Cd drive drivers
    Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
    Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
    Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
    Aug 12, 2008 | MSI (X52) CD-RW/DVD-ROM (Combo) Burner
    Uninstalling program from the computer?
    1. Go to Applications 650_app.gif (info).
    2. Open the Menus 650_menu.gif (info).
    3. From the App menu choose Delete.
    4. Tap the name of the application you would like to delete.
    5. Tap on the Delete button. Tap on the Yes button to confirm that you wish to delete the chosen application.
    Delete programs from your Z22 by using your Z22 and not your computer
    Jun 05, 2008 | Palm Z22 Handheld
    Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
    188 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
