Question about Dryers
Start knob broken off
I have a GE model DCLR333ETOWW dryer that is great, but the start knob got broken off in a move. Where can I find a replacement part?
Thanks!!
    Sergeant:
    Champion:
  • 262 Answers
G/E customer service can help you the number is 1-800-626-2001 or even a local appliance store can order it
Posted on Dec 06, 2007
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
All mechanical function work well except dryer will not heat up ,blowing cold air.Model DCLR333ETOWW GE
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Kenmore 62822 Electric Dryer
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 | GE Dryers
The start knob on my GE Model 453 Dryer is stripped and the metal shaft can't be turned with pliers so I can't start the dryer. Can this be fixed?
The timer needs replacement.
Visit Repairclinic.com and type in your full model number, and all the parts available will list.
If you own a phillips screwdriver, you can replace it in under an hour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 28, 2010 | GE Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
May 21, 2009 | GE Dryers
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
290 people viewed this question
Top Dryers Experts
Marvin
Marvin
