Question about Tripp Lite Lite Internet Office 500 UPS System
Tripp lite internet office 500
How do I change battery?
Quit out the screw in the back of the equipment, QUit out the battery power supply under the device.
Greetings
Posted on Dec 27, 2007
Why is my tripp lite 500 only working on one side?
Go to Tripp Lite web site to troubleshoot the problem. Surge suppressor might have blown.
Jul 25, 2014 | Tripp Lite Computers & Internet
Replacement of Tripp Lite Internet Office 500 UPS batteries
These units have deep well holes that usually have phillips screws to remove... a 8 incl long phillips screwdriver should work... just be careful..
Feb 06, 2013 | Tripp Lite Computers & Internet
Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
I need help in hooking up a new circuit breaker for my internet office 450. Does it matter which of the two wires I connect to the breaker?
If there is only two wires, the breaker is a current sensing device which connects in series with the circuit. which wire goes where should not matter.
Oct 10, 2009 | IBM Tripp Lite Internet Office 500...
I have an INTERNET750U -bottom row plugins no power
Without seeing the back most UPS units have one set of outlets that are surge protection only while the others are from the inverter (battery) . Dead battery or blown fuse !
Sep 07, 2009 | IBM Tripp Lite Internet Office 500...
Can't get my Tripp Lite INternett Office 700 working
You need to look at the batteries..in order for the unit to turn on..the batteries have to be significantly charged up ...measure the batteries with a voltmeter with the unit unplugged...they should be roughly 12.5 to 13.5 volts...if not..you need new batteries
Jan 03, 2009 | Tripp Lite Internet Office 700 (DHIO700)...
Trip.Lite Internet Office UPS 350U Problems
it's mostly a battery issue..how old is that unit?
Mar 27, 2008 | Computers & Internet
IBM-OP500 Battery back-up
Have you tried pressing and holding the off\on switch to make sure it toggles to "normal" rather than "charge"?
Oct 23, 2007 | IBM Tripp Lite Internet Office 500...
Tripp Lite Lite Internet Office 500 UPS System Logo
260 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
